low water pressure (1 Viewer)
Happycampers1
71
29
St Leonards, Hampshire
Swift Kon Tiki 665
Newbie
Next newbie question.....I have filled the fresh water tank and everything seems to work fine exept the tap in the kitchen sink. The water trickles out even with the pump on. The bathroom is fine. Any ideas please?
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Probably air in it keep running it till the air comes out, on your other thread about your water tank , is the tank in the wardrobe, if it is lift the piece of ply up with a hole in then you will find a tap at the bottom of the tank, if it's the same as our compass, no guarantee :Doh:
43,329
49,444
if the pump runs continuously at full speed with the dribbling tap open then you may have a leak in the pipework to that tap.
But.....try unscrewing the filter on the end of the tap outlet (if it has one....most do).
It screws inside the spout and could be clogged with limescale.
Failing that it could need a new tap.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
Has it got an inline water filter in the pipe work before the tap in question.
If so that could cause it.
