Loss of power
Discussion in 'Tech/Mech General' started by wildbilly, Apr 14, 2010.
  1. wildbilly
    wildbilly Read Only Funster
    Jan 11, 2010
    23
    Devon
    I was just pulling away from the Tamar bridge on sunday, high revs in third, changed to fourth and the engine lost power. Changed back to third, up revs back to fourth and the same thing happened. Tried a third time, this time the van took off as usual. Fiat 2.8 JTD engine.
    Has anyone experienced similar problems?:Confused:
    Had thought about possible fuel filter clogged!!
    Bill
  2. Robinhood
    Robinhood Read Only Funster
    Mar 7, 2010
    159
    Sherwood Forest
    I doubt this is the same issue, since it is not an intermittent problem once it has happened, but worth a check at least since it is easy to do.
    I lost power joining the A64 a couple of years ago. Accompanied by a definite change in underbonnet noise.
    Having read of problems elsewhere, I guessed (correctly as it turns out) that the turbo intercooler hose had blown off.
    Incredible difference in performance.
    Common problem and easy to check if you know what and where the intercooler is.
    Luckily the hose clip had remained on the hose.
    B*gger to get at with the tools I had on me though, and made worse by being half on half off the carriageway.
    But don't you feel good when you diagnose something like that correctly AND also manage to fix on the roadside. :RollEyes:
  3. wildbilly
    Jan 11, 2010
    23
    Devon
    Cheers for the info, I will give it a looking at this week end to see if there are any splits in the hose etc.
    Bill:Smile:
  4. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,358
    1,443
    Suffolk
    Feel all along the hose to check if part feels spongy----it is known for the inside to collapse
    and restrict airflow.
    I have also learned from past problems------change fuel filter and change/clean air filter.
    Good luck
    Nigel & Pamala
