looking for VW camper van specialist in wolverhampton or surrounding area
Discussion in 'Motorhome Chat' started by russT25, Mar 9, 2012.
  1. russT25
    russT25 Read Only Funster
    Mar 8, 2012
    20
    Wolverhampton
    Hi,
    I just bought 1989 VWT25 camper van with a fair few niggles that need sorting out. Does anyone here know of a VW camper van specialist or somewhere capable of giving my new van the once over so I can compile a list of required jobs and subsequently prioritise and get said jobs done.
    Any help greatly received as I,m 100% newbie.
    Regards
    Russ
  2. russT25
    Mar 8, 2012
    20
    Wolverhampton
    priority electrics
    The man who sold the van to me explained that the leisure battery will lose charge in less than a week if the van is not driven. ( even if not using any electrical items).
  3. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,076
    1,228
    St Albans
    Chances are that is because of little bits of kit are drawing power without you knowing. :Eeek: Very common, most motorhomes do it. Called parasitic drain, it is fixed by isolating the battery with a switch or simply disconnecting it when the vehicle is not in use.
  4. poppys
    poppys Read Only Funster
    May 8, 2010
    166
    41
    Norfolk
    I think you would be better off finding a web site dedicated to your T25 such as "brickyard".My son had one of these vans and found that there is a wealth of info on these sort of sites.
  5. Janine
    Janine Funster Life Member
    Aug 22, 2007
    5,012
    8,151
    Sunny Shropshire
  6. gozomike
    gozomike Funster Life Member Life Member
    Mar 16, 2010
    876
    663
    Warwickshire - sometimes - but not often
    Sorry but that is rubbish. If that is happening either something is discharging it or the battery is knackered with a very big K
    Mike
  7. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,076
    1,228
    St Albans
    Depends. If it is the chassis battery then no it should not go flat quickly. However it is a problem with habitation batteries. In mine for example the gas detector, alarm system and other bits and piece take a 0.3A constant draw from the 220A of batteries and is monitored with a BM1 battery monitor. Allowing for a usable amount of 110A from my batteries then they are stuggling after a couple of weeks. So I keep a little trickle charger on them.
    • Like it Like it x 1
  8. russT25
    Mar 8, 2012
    20
    Wolverhampton
    Thanks for advice
  9. russT25
    Mar 8, 2012
    20
    Wolverhampton
    I think from what you saying super mike
    That it's probably the alarm system or something
    That is slowly draining the leisure battery. There is a switch on the battery which if switched off the battery holds its charge. I thought at first that this was installed by the previous owner as a compromise or temporary fix but maybe this is normal thing to do. I have checked out website for company on Telford and they can do full inspection of all electrics and gas system for the fee of £135 +vat. Maybe be worth paying that out to find out for sure what state the whole van
