Locker extra security
Discussion in 'Tech/Mech General' started by Doddy999, May 29, 2010.
  1. Doddy999
    Doddy999 Read Only Funster
    May 3, 2010
    160
    13
    Exeter Devon
    Can you experts out there tell me the best type of locks or security for side
    lockers, as they look very easy to break :Eek!:
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,892
    17,553
    YO11 2BD
    they will always be easy to break into as they are only a foam sandwich or fibre-board...no real strength in either.
  3. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    I have noticed on one of my lockers the arm does'nt seem long enough, only seems to touch the rubber. If you pull the locker it can sometimes come undone without unlocking it.:Eeek:
    Can longer ones be obtained to make a better hold?
    Sorry to keep asking all these questions:Wink: Newbies hey:Smile:
  4. chesterfield hooligan
    chesterfield hooligan Funster
    May 12, 2009
    1,026
    499
    Stanton Hill
    :Rofl1:Leave the Dog in there as a deterant !:Rofl1:
  5. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    She would'nt fit in.:Laughing::Laughing:
    Whats that Luv, :Eek!:
  6. vindiboy
    vindiboy Funster
    May 22, 2008
    488
    Fiamma Security Products 13 Items Displayed
    FIAMMA SAFE DOOR
    DESCRIPTION
    Pivoting safety block for motorhome and caravan door. It works as an anti-theft device preventing access into the vehicle via the door. It is made of sturdy anodized aluminium without plastic parts and is fitted with a high security barrel lock. It can be easily installed with bolts and internal counterbrackets. Right or left hand installation. Dimensions: 15x9x4.8 cm. Finished in Polar White.
    ONE KEY SYSTEM: Also available in pack of 3 with One Key System. One Key System eliminates the need to carry a separate key for each lock fitted.
    SPACER KIT SAFE DOOR:
    Spacer to be combined with Safe Door and Safe Door Frame to reduce the gap between the motorhome wall and Safe Door. Suitable for version 2007 only.
    DELIVERY: NEXT DAY (excl. weekends). Delivery Info
    v I use these locks for my locker doors, they are easy to fit,and come in two lengths to cover the existing lock key hole when in use, I am not sure if a picture will appear, but Google Fiamma Security to find them.
  7. MicknPat
    MicknPat Funster
    Dec 16, 2007
    629
    2,996
    Touring UK
    Doddy,
    Can the locker arm be unbolted, if so I'm sure a longer and possibly thicker one can be fabricated.
    Mick
  8. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    Hi Mick
    Have come to that conclusion myself, I deal with a company here in Exeter, so
    will take one off & get them to make me longer ones.
    I have also used nut & bolts straight through with washers this has strenghtened the
    plastic locks.
    Thanks Doddy
  9. vindiboy
    vindiboy Funster
    May 22, 2008
    488
    Yes you can take them apart easily, BUT I think that if you fit longer arms you are asking for trouble as you are making it easier for a robber by making a longer lever to pull on ,thus it will be easier to rip the whole thing out of the flimsy side walls of your van, I have seen this happen with the type that doubles as an aid to entering the Habitation door, [ folding handle type. ]:Eeek::Eeek:
  10. hallii
    hallii Read Only Funster
    Apr 23, 2010
    61
    Worcestershire
    I have fitted these
    [​IMG]
    To the garage doors on my Hymer 522.
    I used steel cavity fixings to bolt a steel plate to the door inside panel and bolted the lock to that. I had to extend the keys though, they were about 5mm to short.
    You could use the through bolts provided but that would leave two domed bolt heads on the outside and I didn't want that.
    To find them do a Google on "garage door lock". I bought mine from a local locksmith.
    Hallii
