locked storage locker.
Discussion in 'Motorhome Chat' started by monzer, Jul 11, 2016.
  1. monzer
    monzer Funster
    May 17, 2016
    78
    77
    Aberdeenshire
    Any idea how I can get in to my outside storage locker. My chocks are in there and I can't get it unlocked. She's an old van (25 years) and when I bought her most of the locks had failed but were easy opened with a flat head screwdriver. Not this one, it turns with a screwdriver but that doesn't seem to unlock anything. Tried all the different keys I had but no success.
  2. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,519
    9,941
    If its reached that stage then you will need to replace the lock anyway
    2 ways are fairly straight forward
    use a large flat screwdriver and tap it into the lock using a hammer then turn to release
    or drill out the lock
    just thought of a couple more, bend a coat hanger to jamb into the lock then pull hard to remove the barrel. only works if the lock is spinning because the circlip has come off the back
    some of the really old locks if you fit a flat screwdiver bit in a drill, you can use it by pulling on the door as it spins the lock to get the screw on the inside to unscrew. sounds more complicated than it is in reality
  3. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,389
    2,659
    Surrey
    Depending on how violent you want to be, you can employ the car thief trick, use a double handled corkscrew to bust out the lock. You will of course need to repair the damage as the barrel comes out!
    • Like Like x 1
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,800
    13,448
    Bolsover, Derbyshire
    try pushing the door in while you turn, presuming of course you haven't already, takes the pressure off the catch, it might just turn
  5. Tootles
    Tootles Funster
    Sep 14, 2013
    9,135
    32,599
    Lancaster
    It sounds as though the lock barrel is turning, but that the 'flats' on it have worn away, not allowing the catch to rotate with it. Drill it out with a wood auger thats just a bit smaller then the surface of the lock face, then you dont damage the edges of the hole. (y)
    http://www.ebay.co.uk/bhp/motorhome-locker-locks
    • Useful Useful x 1
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,907
    17,578
    YO11 2BD
    Wood bit in a metal and brass lock. ?
    A cylindrical hole saw will work better.
    Maybe 16mm
    • Like Like x 1
  7. Tootles
    Tootles Funster
    Sep 14, 2013
    9,135
    32,599
    Lancaster
    Their not real 'metal' John, only 'monkey metal'. A wood auger soon shifts them. (y)
  8. pappajohn
    Aug 26, 2007
    29,907
    17,578
    YO11 2BD
    I'll take your word for that....Never had to drill one.
    • Like Like x 1
  9. Tootles
    Tootles Funster
    Sep 14, 2013
    9,135
    32,599
    Lancaster
    I have a pile of the things, you get yet another load every time you buy another drill set, and the best thing is, their sized.
  10. RogerThat
    RogerThat Funster
    May 20, 2016
    301
    313
    UK
    Can you get to the back of the lock from inside the vehicle?
    • Like Like x 1
  11. movan
    movan Funster Life Member
    Dec 2, 2009
    13,589
    24,545
    Moving around
    As above but mine keeps locking shut too ... I have to bang the two pushing knobs side of the door a few times but REALLY REALLY hard so it hurts my hand ... then for some reason it unlocks on the key turn bit.
  12. monzer
    monzer Funster
    May 17, 2016
    78
    77
    Aberdeenshire
    Sorry I wasn't receiving alerts so didn't notice the replies. I've tried pushing the door in while turning the lock and banging the life out of it but no luck.
    I've got plenty drill bits and cutters at work so I'll have a better look at it at the weekend.
