lock/unlock cap!!! (1 Viewer)
mariner41
23
scotland
Elddis Autoquest
3 years
Hi All
Can anyone help me:cry:
The cap on my water tank is driving me nuts.
Is there an easy way to lock/unlock it.
I manage to fluke it eventualy but dont know what I've done.
I've just given up and going to watch the football:Eeek:
Its an autoquest
Jim.
N
N Luyetund
Short answer... no!
It's a well known problem...especially in the colder months
Some folks have taken them apart, other sprayed them with allsorts... one thing that often works is to drop it into a bowl of warm (not boiling!) for 5 mins but it seem to be a temporary fix
Feb 18, 2009
574
250
Guisborough North Yorkshi
Malibu T410
Since August 2008
unlock cap
As posted in the post above drop the cap in hot water. We had this problem with the cap on our Burstner when it was only a few months old and were advised by Discover our dealer to drop it in hot water and leave for 30 mins.It worked but they did eventually change the cap for one they had in stock -Sue
Aug 1, 2007
1,288
275
Billingham
since 2003
Hi All
Its an autoquest
Jim.
no they don't work
mariner41
mariner41
23
scotland
Elddis Autoquest
3 years
lock/unlock cap
Hi All
Still had no luck trying to lock the water filler cap:cry:
Is there a cap I can buy to fit it.
Jim.
43,323
49,422
i have a 100% positive solution.....
dont lock it.:Doh:
is anyone really going to pour any obnoxious liquids in there.....i doubt it.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Hi All
Its an autoquest
Jim.
They are useless, but buy a can of silicon grease, prise open gaps between the two halves and squirt in as much as possible. It may then eventually work. Ours does.
Decmac
50
3
Locking!! cap
Hi, have the same problem with my water (locking!!!) cap. It just doesn't lock. I am afraid it might fall off sometime but it hasn't yet. I have asked several people to try and lock it but they all give up after a few minutes. My van is a Burstner Aviano i684. Any ideas out there other Burstner owners? Sorry for your plight with your cap. I know, it can get to you or get the better of you. It should be so simple: lock and unlock. . . but not in our case
Feb 18, 2009
574
250
Malibu T410
Since August 2008
Locking cap
Hi Decmac we have the same model on a 08 plate as I posted above we were told to put in boiling eater which worked but then stuck again so Discover changed it when we called for some repairs.You could try them but don,t know a price as ours was under warranty.
Another topic have you had problems with your drivers slide window leaking we are still waiting for a replacement seal. -Sue
drs
89
Ware, Hertfordshire
Coach Built
We have the same problem. We only found out when we had a habitation service and they locked it for us which was great but we could not get it to unlock. The retaining part of the the lock even fell out eventually sorted it out so now do as we usually do and leave it unlocked.
suavecarve
7,547
38,945
Surrey/Hants
Rollerteam 685
July 09
I thought I might be of some use here as I know where the caps lock key is. UNFORTUNATELY MINE KEEPS GOING ON AT THE WRONG TIME.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Hi All
Its an autoquest
Jim.
Hi, Mariner, mine was sticking, so just gave it a squirt of wd40 (in the key slot) and its been ok since.
Cheers, Dave:thumb:
Pikey Pete
1,481
1,143
o
o
At the risk of being shot down, and assuming we are talking about the standard white lockable cap.
I have no problems with them at all. When locking turn the key clockwise and then remove the key and push the cap in against the spring and rotate clockwise, it is then locked.
To unlock, turn the key anti-clockwise, push the cap against the spring, rotate the cap anti-clockwise and remove.
Pete:Cool:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Hi Jim I had probs with mine would not come off for love nor money, took the whole lot off and replaced it with a FIAMMA the type with 3 lugs easy to lock no further trouble:thumb::thumb::thumb: Pete
Tony Lee
274
15000km is a bit far to go and check it, but I thought on mine the key could be rotated in either direction without hitting any stops but the key could only be removed when the key slot was at right angles to the handle. If the knob clicked when you went to push in and turn anticlockwise, then put the key back in, turn it 180 degrees and pull it out again and it should be able to be turned and removed.
I'll check it end of feb when we return.
GJH
29,450
38,827
None, now sold
2006 to 2022
Pete:Cool:
Same works for me as well - except that when locking I rotate the cap first, before using the key.
The fact that I've posted this probably means I'm now in for heaps of bother with the cap in future :Eeek:
Graham
dikyenfo
44
lincoln
A class Mc Louis with small trailer
1 year
I had mine sieze up the same as all of you but I replaced it with the type which has 3 spiral slots inside the totally flush cap. It is slightly awkward to use but never fails to unlock. as only a 1/4 turn is req'd. The sort previously on was ot the 'T'handle type and was rubbish. I bought mine in France at the best shop I have ever seen. YPO at Nantes situated just off the ring road where the N137 meets the ring road. Most important price under a fiver.
Decmac
50
3
Locking cap
Hi Sue,
Mine (ours) is on an 08 plate as well, so they should be very much the same. Never heard of the boiling water trick before, but is it only a temporary fix? I think I will contact the dealer we bought from about it but will try any fix that anyone suggests before we do that. You ask about the drivers slide window leaking - yes we had a bit of a problem of sorts with that particular side recently when raining but I think it was the way we were parked, slightly higher on one side with the result that all the rain was running of van at that side. As far as I remember all I did was the open the window when the rain stopped (miracles do happen!) and I pushed the seal towards (inwards) the window and that seemed to solve it. Maybe your seal is perished, but it shouldn't be with a new van. No much rain came in in our case as we just kept soaking it up with tissues and the like. You should try running a hose (very easy) against it and see what happens, maybe the seal needs to be pushed in like mine so that it is flush against the window when it is closed. Hope this helps to solve your problem or goes some way towards that end. Hope your enjoying your van, we certainly are, beautiful van the Avian. Stay in touch, we could swap info and help each other with small problems as above. I can forward my e-mail address if you like or send private messages re little probs. All the best. Regards . . . Decmac:Smile:
