Location of leisure battery fuse (1 Viewer)
Mack100
766
2,697
Swift
My Dometic fridge is playing up and the engineer we use has suggested removing the leisure battery fuse for 30 minutes to see if that may reset the fridge.
I've had a look on the Sargent site and can only find that the "fuses are remotely located near the leisure batteries".
I've had a look but can't see any so I'd be grateful for ideas.
DBK
18,017
48,061
Plympton, Devon
PVC, Murvi Morocco
If you can get to the leisure battery, you could just disconnect it, but if you have solar make sure you disconnect or cover the panels before reconnecting - or do it at night. :)
Jul 29, 2013
9,069
18,476
Salisbury
Hymer B678DL A class
since 2011
Ours is actually in the battery compartment.
Mack100
Mack100
766
2,697
Swift
Sounds daunting for fumble fingers me but I'm willing to have a go
I'll have another look there
Zigisla
2,579
3,104
Gosport, Hants
Sunlight A72
Getting better month by month.
Couldn't insert the link for some reason, so cut and paste. If I have the correct unit now.
The following table shows the fuse allocation for the 15 fuses fitted to the PSU. Please note that fuses
are dependant on PSU versions, so not all fuses may be present.
Fuse Rating Fuse Colour Description
1 20 Amps Yellow Motorhome Fridge
2 15 Amps Blue Motorhome Towing
3 7.5 Amps Brown Motorhome Marker Lights
4 15 Amps Blue Motorhome Fridge D+
5 10 Amps Red Fans
6 10 Amps Red 12V Sockets
7 10 Amps Red Front Internal Lights
8 10 Amps Red Water Pumps
9 15 Amps Blue Electric Step
10 10 Amps Red Motorhome Tank Heaters
11 10 Amps Red Auxiliary Supplies
12 5 Amps Tan Electronics
13 5 Amps Tan Ignitions
14 10 Amps Red Rear Internal Lights
15 25 Amps Clear Charger (fitted internally to PSU)
Reactions: DBK
