load terminal on charge controller
Discussion in 'Solar Power' started by seanoo, Dec 26, 2014.
  1. seanoo
    seanoo Funster
    Nov 14, 2009
    360
    215
    normandy
    hi , is there any reason that i shouldn't connect my tv and 12v skybox to the load terminal on my mppt solar charge controller? tv is 30 watts and box is 18 watts. at the moment i power them from the cigarette lighter socket behind the tv but the wires are very small and travel about 8 metres before they get to the sargeant power supply and then another 4 metres to the batteries which i'm sure wastes power . cheers sean
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,850
    5,127
    Guisborough
    One guess would be that if you did that you would not be able to isolate it by turning the control panel off so could potentially leave a draw on your batteries. The long cable run you describe will not waste power as such but it will increase the voltage drop along the run so if the TV was shutting itself down for low volts that would be an argument for changing things.
    I think the idea of the load terminal is that you can have something that is always on irrespective of the control panel setting so an entrance light or monitor of some sort.
    • Like Like x 1
  3. hilldweller
    Dec 5, 2008
    26,891
    25,740
    Macclesfield
    The load terminal might be set to activate on light/dark or by timer.
    • Like Like x 1
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    I run my TV and sat box via a 150W inverter connected to the load terminal. That way when the battery level falls to 50% the power is automatically cut off thereby protecting the batteries.
    • Like Like x 1
  5. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    261
    182
    Rushden, Northants, UK
    The LOAD terminals are for any load that needs to be disconnected if the battery gets down to being nearly completely exhausted.
    I route all of my 12V loads through both controllers this way, thus giving the battery over-discharge protection.
    Only very heavy loads such as inverters which have their own low battery cut-off need to go direct to the battery.
    The output is not dependent on the solar panels operating or not, the output is maintained as long as the battery volts are above the cutoff point.
    Peter
    • Like Like x 2
  6. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,185
    14,957
    Leeds the one up North
    Nice to see you have joined FUN Peter, I only just clicked who you are :xThumb:
  7. funflair
    Dec 11, 2013
    4,850
    5,127
    Guisborough
    Sshhhh
    He's incognito.
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,321
    YO11 2BD
    I have an auxilary load output on my bluesky energy controller....can be set, via internal dip switchs, to 2amps for engine battery charging or 20amps general loads.
    Activates at 12.6v or above....turns off at 11.5v.
  9. Peter A Forbes
    Nov 23, 2014
    261
    182
    My screw-up, I didn't twig at the registration stage which was screen name and which was username :)
    Peter
    • Like Like x 1
  10. Techno
    Jul 28, 2010
    14,185
    14,957
    Use the "report" tab to contact Jim or whoever is on the other end. I believe you can request it be changed?
  11. Peter A Forbes
    Nov 23, 2014
    261
    182
    Thanks, Andy, I'll leave it as it is for now, It's a PITA to change a registered member's details, I know from my own forum, but thanks for the thought.
    Peter
  12. Techno
    Jul 28, 2010
    14,185
    14,957
    PITA it may be but let Jim be the judge (y)
  13. Techno
    Jul 28, 2010
    14,185
    14,957
    BTW following a pm about suitable crimps for solar cable to terminate in this mppt unit.
    [​IMG]
    I know they come with bare crimps where originally you got nothing! Peter's communication with the seller got these included but they are not very good. The main problem being length I found some long enough but I had to file them to reduce the width.
    A recent search found these and they are spot on
    http://www.ebay.co.uk/itm/190877248946?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    [​IMG]
  14. Peter A Forbes
    Nov 23, 2014
    261
    182
    I think we ended up with Yellow straight pins by memory.
    Take off the Yellow crimp sleeve and solder the wire in.
    The solder loop just needs easing past the plastic slot on the controller, but it does fit :)
    I've got some pictures somewhere....
    [​IMG]
    [​IMG]
    That is 6sq mm stranded cable.
    Peter
    • Like Like x 1
  15. Techno
    Jul 28, 2010
    14,185
    14,957
    The crimps I linked to are absolutely perfect if you just flatten the end.
    Here with the rubbish supplied
    [​IMG]
    Right up tut chonks!
    [​IMG]
    • Like Like x 1
  16. Peter A Forbes
    Nov 23, 2014
    261
    182
    I found those a bit 'flexible', Andy, but perfectly OK for the job.
    We don't use the finger terminals for anything, but do use the pins.
    Bootlace ferrules are too big at 6mm, and the cable won't go in by itself, so one or the other has to be used.
    The best solution as I mentioned to Eric Hsiao would be to make the terminals bigger.
    Peter
  17. Techno
    Jul 28, 2010
    14,185
    14,957
    Yes the terminal size it ridiculous.
