Live 12v feed needed (1 Viewer)
dryfly
York
20 years
I require a permamently live feed to a dash mounted socket on my 2004 Fiat Ducato 2.8. Can anyone provide me with details of the nearest suitable live wire to the cigar lighter ? The feed is only required for powering a 2amp charger and I intend to use a Scotchlock and inline fuse.
Nov 4, 2011
5,917
38,638
Uk
The cigarette socket on ours is live all time so take it off that.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
When you have repaired as many Failed Scotch Lock connections as the average mechanic has, you too will also have an inbuilt hatred for them.
Simply find a permanent live fuse and remove it, push in the piggy back circuit extender. Use the removed fuse in the correct slot to reinstate the ciruit, and away you go,then simply fuse the other slot to suit your purpose
All fuses where they should be, in the fuse box
Minxy
32,623
66,459
E Yorks
Carthago Compactline
Thanks Geo ... I never knew they existed ... could proves useful for my next little job!
D
dryfly
York
20 years
My cig lighter is switched hence the need for another socket.
Geo - What is a circuit extender?
Zigisla
2,576
3,101
Gosport, Hants
Sunlight A72
Getting better month by month.
Can those Piggy Back fuse holders that @Geo linked to be used in the front of the Electroblocs or only from the main fuse panel?
Lenny HB
53,280
149,390
On the coast in West Sussex
Hymer B678 DL
Yes providing you can find enough room, knowing what wiring to Elektroblocks is like.
