lights (1 Viewer)
May 8, 2016
1,685
80,569
silver coast, portugal
C Class: Low profile
Boatie for 20 years
Hi and a belated welcome
It would help to know what van you have, make, model, etc
I see you have a Lunar Champ listed on your profile. A601 has a slight problem with wiring. There is a multi connection block located in the wiring loom in the channel below the run of wall cupboards above hob/sink. This was slightly loose and just needed pressing together, could give an intermittent fault.
There is an article here on the subject, but you have to sign in to see it: www.clubmotorhome.co.uk/forum/14-batteries-and.../2180-faulty-lighting-circuit
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
From what you say. I would be looking at any work carried out as result of the MOT, to see if this affected any wiring
Other than that you may. Have multiple lamp failure possibly due to over voltage and or age. Substituting bulbs would be the way to rule that out. Some switches can be suspect or a displaced connection.
Pete
May 8, 2016
1,685
80,569
Boatie for 20 years
Hi plumber. Though so from your profile. Could be multi connection block located in the wiring loom in the channel below the run of wall cupboards above hob/sink. If slightly loose this just needs pressing together, could give an intermittent fault. Alternatively, look underneath van to see if they dislodged anything when checking handbrake cable, exhaust or in any of the wheel areas. Almost certain to be a loose connector. Possibly worth taking vehicle back to MOT place and telling them, as they will have ramps, lifts or a pit (anything better than using a jack)
