Can anyone help with two issues please: My van is a Hymer B544 SL 2007
First one is that the Daytime running light bulb needs replacing. The Hymer manual states that these bulbs are changed from the engine compartment. I can't see that there is enough room to access the rear of the unit to turn the lamp holder. If I have got this wrong then I will persevere but is taking the whole unit out the only other option? Also is it worthwhile putting a lower wattage bulb in as a replacement?
The second relates to the location of the lower marker lights fuse. One of the lights was not working so dismantled the holder and and replaced with a new bulb. It did not seem a good fit and when trying to make a good contact all the other marker light went off ?fuse blown.
Many thanks,
Jack.
Many thanks,
Jack.
