Light ingress? (1 Viewer)
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
I keep thinking this is a daft question but...
When we sleep in the MH the light that bypasses the blind in the mornings is huge. There is some felt at the bottom of the window which I feel should help blank it out but it isn't helping.
Do others suffer this problem? and what do you do about it?
TheBig1
17,605
43,102
if you have the older version pull down cassette type roller blind then this has always been a problem. we found that pulling down both the net flyscreen and the blind cut out the most light but certainly not all
Welsh girl
3,658
3,036
Globecar
Since 2004
You can use some of that pipe lagging you buy in b and q.
Cut a slit in them and thread them over the bottom of the blind.
It can be left on I believe.
It used to be a real pain when we had blinds like that.
We have the pull up ones now.
Much better.
Oct 28, 2013
490
443
Lincoln
Van Conversion
We did away with our blinds as soon as we got the van, largely because most of them were fubar and obsolete.
We replaced them with some made to measure black-out curtains which seem to do the trick and were considerably less expensive than replacing all the blinds would have been had they still been available.
Upon reflection, the above is probably not particularly helpful but it seemed relevant at the time....
golly
2,005
69,581
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Much better.
This does work on the roller type blinds, we used it when we had our caravan.
Oct 20, 2013
5,299
13,069
South Norfolk
Yes
Normally, I would try to help, but you've not been overly nice to me lately.
mikebeaches
5,392
8,594
Bristol
Rapido V68 Van Conversion
Since 2009
Eye shades from Poundland or the 99p Shop will do the trick - no problem. Ours came with ear-pugs too, which can be handy on occasion. :thumb:
Mike
grasscutter
2,469
8,592
East Wittering. West Sussex.
Hymer Exsis i588
Started in 1980
To help with the winterisation in our van I used thin foil insulation to make secondary covers for our windows. This actually sorted out the problem we had with light ingress.:thumb:
