liesure battery (1 Viewer)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
You've got to put a known load on it, run it down to 12V and then work out how many ampere hours you got out of it.
Just like running your diesel tank dry, it's the only way you know what you're going to get out of a tank.
Paramotormanal
82
56
Kingston upon Hull
Just pop along to any motorist discount centre who sells battery's they will do a drop test on it for you free of charge lol pardon the pun, make sure it has had a full charge the night before, I have one of these units if you have a weak battery it will detect it.:thumb:
43,303
49,290
I may be cynical, but...
in an ideal world....yes, your battery is good...we need not sell you a new one.
In the real world....batteries buggered mate, we have this one in stock. :Doh:
1,059
2,318
Hollywood, Birmingham.
A Class Laika
Since 2011
There are many posts on all motorhome forums on this subject
This is not always true. I recently had to replace two Banner batteries and was fortunate to live near to the Banner depot. They did the drop test and informed me that the batteries were ok. I had checked the batteries myself and found that they provided only 3 Amp hours of use for each battery. Banner then agreed to bench test them and found them to be faulty in deep cycle mode but ok for engine crank amperage.
I agree with the first reply, fully charge the battery, disconnect the charger, leave for an hour to check that you have about 12.8 volts at the battery terminals. Then run a 5 Amp load till the battery shows 12 volts and check the elapsed time to give the Amp hours.
There are many posts on the forums on this, thats how I got to the bottom of my problems with the Banner batteries.:thumb:
Paramotormanal
82
56
Kingston upon Hull
Two true but you have to start somewhere and my snap on drop tester will certainly detect a weak battery and you can cook your toast on the bars whilst it is lol::bigsmile:
43,303
49,290
won't do your leisure battery any favours though.
A genuine leisure battery is designed for long, low discharge currents, unlike the batteries which high current drop testers are intended for, starting batteries, which have a structure designed for short, high current discharge.
Leisure battery current is likely to be around 20amp max for a few hours, whereas a starter motor may draw 600plus amps for a few seconds at a time.
Paramotormanal
82
56
Kingston upon Hull
Bugger shot down again!!!!! What about the toast,too light lol:cry:
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Actually, leisure batteries can be officially rated for quite significant levels of CCA as well, often in excess of the actual starter battery. Very useful for giving yourself a jump start.
