liesure battery wired with a difference?
Discussion in 'Tech/Mech General' started by mick noe, Feb 13, 2014.
  1. mick noe
    mick noe Funster
    Apr 14, 2009
    616
    523
    near Boston Lincolnshire
    I have just fitted a second leisure battery but just to be different:Eeek: thought I would do it my way. Replaced the good van battery and used the old one as second leisure battery wired thus......both neutrals together and lives wired to a marine battery switch which gives the option of using batt 1 batt 2 or both. Also wire individual mini cheapo voltmeters to each battery for individual monitoring.
    My thinking is if van battery fails I have a spare and when and if leisure battery gets low if off ehu I have the back up 2nd battery:thumb: also if I get a battery go down it wont drag the other down and can simply carry on using other battery.......... cannot see a downside...............can you?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,261
    17,928
    YO11 2BD
    cant see a problem, except having to manually change-over to charge batteries.
    • Like it Like it x 1
  3. Geordies
    Geordies Funster
    May 29, 2013
    989
    2,281
    Tyneside
    If you have a high charge in one battery and low charge in the other and you then connect them together there may well be a large amount of current flow. Presumably your wires can take it ?
  4. mick noe
    mick noe Funster
    Apr 14, 2009
    616
    523
    Yes I have heavy multistrand battery cables But as voltmeters monitor batteries individually will know the state of charge and avoid that. thanks for the warning though:thumb:
