Lidl 16th Jan (1 Viewer)
ShiftZZ
21,383
84,494
Dark Side of the Moon
ULTIMATE SPEED® Car Battery Charger
£13.99*Each
Intelligent microprocessor control with diagnostics programme and controlled charging process
With reverse polarity, short circuit and overload protection as well as pulse charge for flat batteries
Suitable for most 6V and 12V car or motorcycle batteries with a 1.2 - 120Ah capacity
4 variable charging rates (max. 3.8A)
Operating voltage: 220 - 240V ~ 50/60Hz
3 year manufacturer's warranty
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Great "mans toy" the digital infra-red temperature sensor... They used to cost nearer £80
Mitch
Scout
3,958
120,888
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
Mitch
I had one of these when I used to breed geckos, I had to know the tempareture of the floor in the differant parts of the vivariums.
Found loads of other ueses for it, like balancing the heat output form domestic central heating radiators.
I wonder were I put it:Doh:
Feb 16, 2013
19,694
51,872
uttoxeter
ambulance conversion
50 years
£13.99*Each
If this is as good as the aldi one it's worth every penny, I have charged everything from my bantam 6 volt battery to my ford 7600 tractor battery, works better than a charger purchased for £60, on my fordson major tractor the dear one wouldn't charge it but this one did.
I know the battery is probably knackered but it charged overnight from dead flat to starting the tractor next morning.
Don't know how they are different but how they are so cheap I don't know.:thumb:
Feb 16, 2013
19,694
51,872
uttoxeter
50 years
Chinese sweat-shop manufacturers
That's not what I meant, I know they can make em cheap like that but I meant size and that, they look a different thing altogether than the old style large humming charger, what's different in them.
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
Since 2010
Thanks for spotting this...I could do with a smarter (and smaller) battery charger than the old Halfords one I've been using.
Plus, I thought I'd got a good deal with the high-vis jacket (to stick in the van) I bought on Amazon a few weeks ago. When it arrived though I realized that it was going to be lovely and warm this time of year, but in the summer I'd be at more risk of heat-stroke if I wore it than getting run over if I didn't :RollEyes: A high-vis vest would be handy.....£1.99! :Eeek:
MattR
4,096
38,501
Beds
Panel van
Years
I have the previous model to this one and it is great. The only problem is that it does not start charging unless there is some charge in the battery. Hence, it will not charge a flat battery but will kick in if I give the battery a few mins charging from a booster battery (the portable battery type used to jumps start cars). Will this pulse feature overcome that problem?
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
I have the previous model also. It actually also has the pulse feature.
Like wise with a battery below 10.5V, it did not want to start on its own, so I put two batteries together, to "fool" the charger. After a short while I disconnected the good battery and the charger recovered the old battery.
However the old battery then charged fully over 24/36 hours, and has been in use ever since.
This has been the best charger I have ever had, and at a bargain price. I will buy this one and leave it in the van in case my main hab charger packs in...:thumb:.
Rob e Lee
452
575
Surrey
Since 2011
Don't know if anyone's posted but these are available again at Lidl - same price £13.99
I bought one last time around fantastic value.
Rob
mikebeaches
5,392
8,593
Bristol
Rapido V68 Van Conversion
Since 2009
Agreed, I bought one about 4 years ago. A great bit of kit at a superb price. (y)
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Use one every day (y) basically exact same as the Aldi one(y)
If your battery gets really low and it won't recognise it as others have said stick a other along side via jump leads for ten mins .....also try letting it charge as a 6 v bile batts for a few hour then change it to 12v (y)...brilliant bits of kit :) It's a pity they don't just work once connected instead of having to press mode button, but for the money nothing comes close
Jul 5, 2013
11,722
13,698
Since 2013
On the recommendation of @dabhand I bought one from a French Lidl last autumn. It works well. Exactly the same, BUT the instructions are in French. Can anybody email me a scan or photo of the English version please.
Gellyneck
9,192
18,137
Scotland
More than toes wet now!
Is this it?
  • 92517_HR_RO_BG_EL.pdf
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
I got a surprise when I found our stored caravan battery had not been disconnected and was down to 7.3v . I brought it home and put it on charge with one of these Lidl chargers.
The Lidl charger went into recovery mode with the display flashing between 7.3v and --- .
I kept looking at it for about an hour with no change. This is explained in the booklet.
Sometime during the next hour it automatically switched over to standard 12v charging and was then showing 10.5v
It then took a couple of days to reach full charge at 13.1v and went into maintenance mode.
I have left it connected now for a further 5 days and today it shows 13.3v
dabhand
4,307
23,934
Staffs
Concorde carver E35
Since 1993
I probably can but I’m in Lanzarote at the moment, let me know if you still need them in a week.
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Great chargers only down side is they have to be manually set to 12v each time so no good to build in permenantly unless accesable
Jan 19, 2014
9,368
24,704
Derbyshire
Elddis Accordo 105
since 2014
I've got one on our engine battery (y). Bought another one for my new motorcycle. They have a gentle charge rate for ickle batteries (y) not only are they a lot cheaper than Optimate/C-tek, they are better.
:eek: sorry :)
Feb 22, 2011
9,762
20,113
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Saw these in Lidl on Sunday and was tempted but didn`t buy, then saw this thread today and thought about how old my existing charger is. I realised it`s 28 years old :eek: .........
Called in Lidl on way home today and bought one (y)
Oct 12, 2009
10,613
23,580
A Class N+B Arto 69GL
Since 2009
I get a bit frustrated when you guys post about these good deals in Lidl as we cannot get them in our Lidl 200m away in Poland. They used to have more techie gear but those shelves are now wholly clothing.
Geoff
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
£13.99*Each
17€ ,99 in lidl In France..ao seems good deal.
Parapilot
214
251
Whiston
Hymer S820
6 years
Also worth noting is the cordless 'dremel' multi-tool at a fraction of the price (only £17.99)
Not sure how I ever managed without one of these - I've had a corded version for many years and find it incredibly useful, especially in the motorhome for fine detailed work. Just bought this for travelling with and it seems pretty good. I've found Parkside tools to be consistently good and almost the same quality as Makita, Bosch etc (with an excellent warranty). Certainly good enough for a non-tradesman DIY user.
Highly recommended if you don't already have one ! (y)
