lever on toilet bowl
Discussion in 'Motorhome Chat' started by Welsh girl, Jun 7, 2011.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,746
    1,334
    living the dream.
    The lever on the toilet bowl is getting difficult to pull, don't want to yank it hard as it might break it, any idea what to put on. it to free it up?
    It would be disastrous if it broke, especially here in France, have another 12days here.
    I don't want to use any oil, I have bought some spray oil in France as we needed it for the entrance step sticking but not sure if it is silicon as it is all in French.
    I understand that some substances will damage the seal and the plastics so am awaiting any replies.
    Please!!!
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,287
    16,960
    Liverpool.
    Whilst the lever is closed tip some olive oil onto the flap and gently open and close it,working the oil into the seal. If its the seal that's dried out this should cure it,if not it sounds like a mechanical issue.
  3. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    First here is some info, giving a drawing of the cassete
    http://www.thetford.com/HOME/PARTS/PermanentToilets/CassetteC200SCSParts/tabid/646/Default.aspx
    Then you can try:>>> is the cassette seated fully into its normal position
    Remove the cassette and check if the valve handle is still stiff. This should tell you if the problem is on the cassette or on the seat.
    If the handle is OK look knob that is to the right of the valve slider, you should be able to open the valve, can you turn by hand, IMPORTANT don't forget to return it to the closed position before putting the cassette back into place.
    After that there is not much else I can offer. but it my help to find the problem.
    Doug...
  4. Welsh girl
    Nov 7, 2009
    2,746
    1,334
    living the dream.
    Worked a treat, thanks for your advice, left vegetable oil in the trap for a few hours as I didnt have virgin oil, lost that years ago.LOL
    Lever sliding nicely now.
