Levelling Ramps
Discussion in 'The Beginner' started by RS SPIKE, May 19, 2015.
  1. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
    Hi, just kitting out our first motorhome and not sure what ramps i require ??
  2. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Thin at one end thick at the other should do it (y) :LOL:
    • Like it Like it x 14
  3. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Have a look on Fleabay there's lots of choice. Milenco are popular as are Thule but in half an hour every make under the sun will have been mentioned on here :whistle: ................ Wait for it ..............:LOL:
  4. RS SPIKE
    RS SPIKE Funster
    Oct 8, 2014
    192
    29
    derbyshire
  5. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,422
    7,760
    God's county. North Yorkshire.
    we have Milenco Quattros they are a bit bulky to carry in our PVC but they certainly do the job. With smaller ones there is a chance you can go over the top ( I know from experience!!)
    • Like it Like it x 2
  6. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Yes we have the Quattro's, I must admit I get SWMBO watch as I drive up them and I agree heavy and bulky but very strong.
  7. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,422
    7,760
    @Badknee the problem is that I have an automatic and its not like you can slip the clutch to gently go up you have to give it a bit of wellie, often (I mean very rarely) with a bad result!;)
  8. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Ah well in that case get the Mrs to throw herself under the wheels to stop you going over the top while you race up them at about 35mph. That should do it :eek: :p
  9. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,922
    1,944
    Warwickshire
    I have the largest size Fiamma ramps (Jumbo I think). They are quite strong with a flat incline rather than scalloped indents to hold the wheels. I prefer the flat format as I can choose exactly where to stop on the ramp.
    Our motorhome is also an automatic but I have not had any problems controlling the ascent. Use left foot braking to hold the vehicle back if required.
  10. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    Milenco Quattro for me.
    My Fiamma ones both snapped in half.
    They don't like softish ground as much as the Milenco ones
  11. chaser
    chaser Funster
    Feb 16, 2013
    7,709
    8,779
    uttoxeter
    We have some of the yellow ones, had them three years , used them once , first time out after buying them, never bothered since, usually get level enough, try the wine bottle on the table , if it stays in one place, we are level enough
    • Like it Like it x 6
  12. TheWM
    TheWM Read Only Funster
    Feb 24, 2015
    445
    450
    London
    What weight you pushing? Most 'cheaper' chocs should be fine - my mate's 5t LT goes on them with no problems.
    A question for you auto drivers - in case I come across anyone needing help. Would reversing be easier onto a choc given the lower ratio gear and easier to control?
    As you all have probably gathered by now - I really don't have a scooby, but I do have a logical mind (no brain though).
  13. Rob and Val
    Rob and Val Funster
    Oct 17, 2010
    930
    2,223
    Lincolnshire
    We used ours once. Van shot off the back and the front of the ramps embedded themselves in the wheel arches. Had to dig holes underneath to release them. Haven't used them since! Anyway, they take up too much storage. We now just pitch up on reasonably level sites. It really doesn't matter too much unless you are parked on so much of a slope that you could fall out of bed at night or that your gas fridge doesn't work.
  14. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    i phone pictures and videos 031.JPG i phone pictures and videos 031.JPG i phone pictures and videos 031.JPG
    5t gross. Always seem to need to level up at the front.
    The MH sits slightly nose down naturally.
    When I drive onto them I use tickover and clutch control with my right foot covering the brake.
    Never had a problem
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    2 x plank
    2 x brick
  16. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    I thought we weren't supposed to mention the Yorkshire Ramps ?
    • Like it Like it x 5
  17. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    Started with Fiamma,they did the job but had a tendency to crack after a yr or so.Tried putting piece of thick ply underneath and they lasted longer.
    Was given a pair of Millenco Quatros to compensate for a company sending us the wrong colour windout awing,they were brilliant but took up too much storage space.
    I now use Millenco Triple and am very pleased with them.(y)
  18. Bartyfixedit
    Bartyfixedit Funster
    Jun 11, 2014
    195
    296
    Maidstone Kent
    I built my camper. Designed into it was storage for milenco quattros. Strong, high and very grippy to climb. I still often end up at the very top, even on Quattros.
  19. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,527
    2,740
    Surrey
    I'm pretty sure ours our Fiamma ones, but they don't look anything like the broken ones that @knokinonabit posted. I did notice at the Newbury show that a vast majority of the vans were not using level up ramps. We only needed on under one of the back wheels. It had sunk into the grass by the end of the weekend though :D
  20. knokinonabit
    Dec 28, 2011
    2,483
    2,453
    They are the Fiamma Maxi. I still have the smaller yellow Fiammas and have no problem with them.
    I use them under the rear wheels when I need to level side to side, rather than fore and aft.
