Levelling Jacks
Discussion in 'Tech/Mech General' started by OldWomble, Jul 1, 2015.
  1. OldWomble
    OldWomble Funster
    Feb 22, 2015
    70
    22
    West Sussex
    Morning all
    We have a problem with our Hymer in that it is lower at the front than at the rear by about 3 inches. This means that, unless we go up on the ramps, the shower tray does not drain as Hymer, in their wisdom, have fitted both outlets to the rear of the van.
    As levelling blocks are a dam nuisance to use overtime we stop I have had a look at other levelling systems but what a price. As I only need something at the front I started wondering about a pair of electric scissor jacks fitted below the chassis and operated by a simple down/up switch to each one. Has anyone tried this or got any thoughts on it?
    Cheers...
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,871
    6,002
    Guisborough
    We have the fully hydraulic version and think they are great, not only for levelling but they can lift the vehicle off the floor completely so there are advantages when you get stuck in a muddy field for example or indeed for tyre/wheel changing.
    There are a few examples of electric steadies on the Internet but they are not really meant to take the load as they are as the name suggests just steadies.
    Martin
  3. mogbl
    mogbl Funster
    Sep 28, 2010
    89
    173
    Castletownbere West Cork
    We had the same problem with our fiat Ducato the front end lower than the rear we had up-rated springs fitted which raised it about 65mm 2 1/2 inch might be the answer cost about €700 don't know in pounds. It made the ride better.
  4. scotjimland
    Jul 25, 2007
    29,042
    25,736
    Suffolk
    As previous post.. fit uprated front springs .. mine is also low..
    been a few threads about them.. about £600 fitted
  5. olley
    olley Funster
    Jul 29, 2007
    3,909
    2,544
    Ipswich
    At that price wouldn't air suspension be a better option jim?
    Ian
  6. scotjimland
    Jul 25, 2007
    29,042
    25,736
    Suffolk
    only every heard of having the springs uprated/upgraded but open to suggestions..
  7. olley
    olley Funster
    Jul 29, 2007
    3,909
    2,544
    Ipswich
  8. scotjimland
    Jul 25, 2007
    29,042
    25,736
    Suffolk
    can't fit air bags on MacPherson struts Ian..
  9. olley
    olley Funster
    Jul 29, 2007
    3,909
    2,544
    Ipswich
  10. Titley
    Titley Funster
    Apr 12, 2013
    97
    144
    Shrewsbury
    Hi Just fitted new front springs on my 2004 Hymer, same problem as yours 3 inches lower at front, fitted Sachs heavy duty front springs from Eurocarparts part no 627580830, £59.94 each problem sorted and handling much improved.
    • Like it Like it x 3
  11. olley
    olley Funster
    Jul 29, 2007
    3,909
    2,544
    Ipswich
    I keep forgetting that you guys don't have cart horse front springs like my RV, makes front air suspension a bit of a non-starter for you.
    Ian
  12. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,281
    6,966
    Spain for the winter
    We have just fitted air ride to the rear and up rated springs to the front. Colin did the air ride himself and Dave Newell did the front springs (just this morning in fact). This is the first time the van has been level when on the level ground since we got her.
    The new heavy duty Sachs springs, new shocks & top plate were £550 inc fitting. This raised the front end by 35ml, and of course we can now lower the back end by letting some air out.
