Leveling jacks (1 Viewer)
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Electric leveling jacks, power systems I think.
Ignition on and the control unit lights up as it should but whatever is pressed no jack movment, up, down or otherwise.
Any ideas?
Si.
zaskar
1,159
371
UK
5th Wheel
Any ideas?
Si.
Somewhere in the main power feed circuit, there may be a circuit breaker. i had this on my Landau, fitted under the hood. Black box, about the size of a matchbox with a lever on it. Sometimes 9usually if i tried to take the jacks to thier limit) it would trip. Just swing the little lever to resett...........if you've go one!:Blush:
HTH
Dodgey
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Found the control box etc, under hood as you say but can't see a cct breaker?
zaskar
1,159
371
UK
5th Wheel
On mine, the controle board and the circuit breaker were two seperate items. Try following the main power feed back from the battery. It was in this line that the circuit breaker was fitted on mine. like you, I had ALL lights on the panel, but no way would those jacks move till I reset the trip.
