Leveling Blocks
Discussion in 'Motorhome Accessories' started by Gizmouk, Oct 4, 2014.
  1. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    997
    1,763
    Essex
    We have a pair of Fiamma leveling blocks - one started to split last month in Scotland, now the other one is showing signs of splitting.
    Only used the blocks a 6-8 times, so not too happy. Fiamma say they shouldn't be used on stones / gravel - which is a bit of a cop out, as it rules out a fair percentage of sites !
    Has anyone else had problems with Fiamma blocks, and / or can anyone recommend a decent sturdy set ?
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,828
    13,500
    Bolsover, Derbyshire
    we have had these for 2 years
    full recommendation from us
    http://www.milenco.com/products/levelling-ramps/
    bought ours before the really big ones came out, we have the Quattro, not cheap, but not broken yet either :D
    edit - actually think the Quattro may be the biggest, I guess it refers to number of different height positions (y)
    • Like Like x 2
  3. Bertie Bassett
    Bertie Bassett Read Only Funster
    Jul 25, 2014
    2,743
    8,714
    Giz, what David said!(y)
    • Like Like x 1
  4. gasman2008
    gasman2008 Read Only Funster
    Aug 5, 2012
    126
    99
    Southampton
    have had a set of Fiammas for 4 years now, used them with our Bongo and with the Auto sleeper Transit. The Bongo is under 2.5 tons and the Transit is under 3.5 tons. Been OK but starting to split now, have bought some Towsure Milenco imitations look great but as yet we have not used them. The Fiamma blocks are lower so take up less room when not being used, and work fine unless the site is very sloping. I think I will replace the fiamma block when they give up. Not sure if this is any help, what does your m/home weigh?
    • Like Like x 1
  5. Bartyfixedit
    Bartyfixedit Funster
    Jun 11, 2014
    195
    295
    Maidstone Kent
    Milenco Quattros for us. Four years old and still working perfectly. 3.5T van
    • Like Like x 1
  6. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    997
    1,763
    Essex
    4.5t
    So well within the rated limit for the Fiamma blocks.
  7. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,400
    7,360
    God's county. North Yorkshire.
    I had the yellow fiammas and thought they were absolute rubbish so got the milenco triples. These were great until I went over the top! That's my only complaint about having an automatic as you can't slip the clutch .
    Anyhow got the milenco quads and these are great, as I only go up to level three to save more embarrassment ! As stated they are big especially as we only have a PVC but as soon as we stop we put them out.
    • Like Like x 1
  8. JJ
    JJ Funster
    May 1, 2008
    14,770
    26,384
    I have never had any trouble with any model of levelling blocks... :wink:
    JJ :cool:
    • Like Like x 2
  9. Wombles
    Wombles Funster
    Oct 28, 2013
    2,432
    1,821
    Somerset
    Another vote for Milenco Quattro -now have these monsters having tried all Fiamma types(y)
    • Like Like x 1
  10. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,082
    8,173
    Forest of Dean
    Had a set of these basic Fiamma for 8 years used on everything from 8ton Rv to current 5ton rig never had a problem and used on every type of surface including snow and ice and minus 25c in the alps. Think I paid about £15 when I bought them originally.
    Keep it simple my motto cant see the need for all these massive convoluted ramps about nowadays.
    http://www.leisureoutlet.com/carava...3xbvZ1uRmR4PNS0AVcSUrvPNPABbkMb32IaAgTv8P8HAQ
    • Like Like x 1
  11. Wombles
    Wombles Funster
    Oct 28, 2013
    2,432
    1,821
    Somerset
    Fiamma ones not high enough for fridge to work on some of the rally pitches we have been on!
    • Like Like x 1
  12. FJmike
    FJmike Funster
    Jul 17, 2014
    782
    843
    Swindon
    Another vote for Milenco Quattros, yes they are big, but are solidly built and being higher than most has resulted in a level van in places like the aire at Le Treport. Would not be without mine.
    • Like Like x 1
  13. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,084
    Leeds the one up North
    Me too Quatros they take a lot of stick as we are near two ton up front.
    I bought another set at Peterborough for £33 bargain!
    • Like Like x 1
  14. Techno
    Jul 28, 2010
    14,138
    15,084
    Sea level or cliff top?
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,940
    17,606
    YO11 2BD
    Rubbish !!!
    More like soft ground, as the thin ends will not sink as far as the centre section and can flex when running up the ramp so causing stress cracks in the center.
    Gravel etc may chew up the smooth underneath surface but the whole levelling ramp is supported on firm ground.
    • Like Like x 1
  16. FJmike
    FJmike Funster
    Jul 17, 2014
    782
    843
    Swindon
    Techno Its the sea level aire that needs the ramps. I wasn't impressed with the cliff top aire, slightly cheaper than below but not much in the way of views that you would expect cliff top and no electric
  17. Techno
    Jul 28, 2010
    14,138
    15,084
    We like the cliff top and the free lift. The sea level one is nice when the barrier will accept your cards and it isn't full
    Both are in my aires gallery via the link in my signature.
    The Funicular aire has been freshly tarmac'd on the upper level where the borne is.
  18. Abacist
    Abacist Funster
    Oct 15, 2013
    1,282
    1,521
    Devon
    Well my Autotrail Savannah at 4.4 ton crunched through Milenco Quattros and I have now cut the broken top ends off which gets rid of both the weight and the broken bits.
    They will only be used as a last resort in future - got a decent quality set of German ones which are not so high but much stronger. I also have a home made set of wooden 3" ramps which are first class.
    • Like Like x 1
  19. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,804
    1,027
    Cark, Cumbria
    Our Fiamma ones started to split at the bottoms too, so we tried the Quattro ones & the tyres keep ripping bits of the tops of them? I can see I'll end having to make some.
  20. Wobby
    Wobby Read Only Funster
    Aug 26, 2007
    83
    55
    Hailsham
    On gravel pitches I just dig two holes for the tyres and drive into them, level!
    On leaving I replace the gravel so the pitch is as I found it.
    Wobby
    • Like Like x 3
