leslie - Sureflo pumps
Discussion in 'The Beginner' started by leslie, Sep 10, 2009.
  1. leslie
    leslie Read Only Funster
    Aug 24, 2009
    5
    Southsea, Portsmouth
    I have just purchased a Fiat Ducato mobile home. It is fitted with a sureflo 16PSI 12V water pump for onboard water. I seem to have a problem with it. It does not seem to have enough suction to pump water up to it. With the pump out and the filter in a bowl of water it seems to pump at a good rate as it has a constant supply of water. However if I connect a pipe and hold the pump 5 foot above the bowl with the pipe in the water it fails to suck up water.
    If anyone has any ideas as to what could be wrong it would be very helpful.
    PS. The motor runs well, and I have looked at the diaphragm and to me it looks ok but I am no expert.
    Many Thanks
    Les:Eeek:
  2. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Sounds like it has an air leak on the suction side.
    If you have taken the pump chamber apart have you either distorted the housing by slightly over tightening or conversely left slightly too lose to let air in, missed any gaskets.
    Are all connections airtight in hoses, It could be a problem with the diaphragm but think I would try everything else first as it will pump.
    Sorry forgot to say WELCOME to MH Fun Les most remiss of me.
    Dave:thumb::thumb:
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,246
    East Sussex 01-580-881288
    Hi Les,
    It is highly likely that the diagraghm is knackered and unfortunately they are no longer available as a spare part.
    Make sure you do not have an air leak on the pump or the connection pipe.
    I believe the ITT marine version pump has the same working parts and I hace a spare used diagraphm, PM me with your name and address and I will post it to you.
    Peter
  4. vwalan
    vwalan Funster
    Sep 23, 2008
    7,606
    3,858
    roche cornwall
    hi leslie. have just rangleisure accessories who were surflo distributers they say if you give them the model number off the side of the pump they can possibly supply the parts diaphram. tel..01603414551.. must say mine as never given any trouble in 10yrs great peice of kit. cheers alan.
  5. leslie
    Aug 24, 2009
    5
    Many thanks for your offer of the diaphragm, I have been given a number of somewhere that may be able to supply a new kit. if I cannot get a kit i may well get back to you. cheers Les
  6. leslie
    Aug 24, 2009
    5
    Thanks for the number I will ring them tommorow. Les
  7. sinbad1
    sinbad1 Deleted User
    I doubt that a shurflo pump would create enough vacuum to suck up 5ft in normal circumstances the supply to the pump would be no more than a foot. its the output that would probably go 5ft. I would check there are no obstructions to the suction side of the pump, you could do this by back flushing with a hosepipe.Having said that any air leak or back flushing due to a perforated diaphragm would prevent any suction on the inlet side.
    regards
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    At 5ft it's close to the limit .. Shurflo say max 6ft .. but that would be a new pump in A1 condition ..
    jim
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    where does the pump normaly sit, surely not 5 ft above the tank!
    if it draws water at low level from a free standing container it will draw from the tank.....unless the pipework between tank and pump is either blocked or letting in air.
  10. pappajohn
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    but then it wouldnt draw water from the free standing bowl at low level either, which it does.
Similar Threads
  1. Jac Sprat
    12
    848
