Leisure or car battery?
Discussion in 'Motorhome Chat' started by Billy23, Aug 7, 2015.
  1. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,570
    2,873
    On a planet...far, ....far away.
    i am at Bristol Balloon meet and need to buy a new leisure battery, I have heard that some people don't buy a " leisure" battery, they just put a car battery in.
    Any suggestions as to which one I should get please.
  2. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    810
    491
    West Country and France/Spain
    • Like it Like it x 1
  3. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,570
    2,873
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,184
    14,128
    Bolsover, Derbyshire
    I am not technical enough to have an answer to your question
    However, they make 2 types, must be a reason
    You need one to start the engine and another for everything else, I recommend you get a leisure battery for the everything else bits (y)
    If you go for more expensive gel types make sure your charger is suitable, probably best to stick with standard acid types and fit the vent tube if inside :)(y)
  5. Hagstrom
    Hagstrom Funster
    Apr 13, 2011
    134
    102
    West Yorkshire
    I understand the new Varta/Bosch Silver Dynamic batteries have been developed for both functions, deep cycle and vehicle start, for cars which now have switch off when stationary and start automatically when you press the accelerator. I believe they are good value.
  6. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,940
    1,959
    Warwickshire
    I spoke to Varta before replacing my leisure batteries last year and they advised against fitting the Silver Dynamic battery for leisure / habitation use. They make a range of batteries designed for the purpose.
  7. Hagstrom
    Hagstrom Funster
    Apr 13, 2011
    134
    102
    West Yorkshire
  8. Doctor Dave
    Doctor Dave Funster
    May 18, 2015
    288
    599
    Wiltshire
    When I had a narrowboat I needed to replace all of my batteries - 1 x engine start and 4 x domestic. I went to a local tyre / battery dealer and after a long conversation re so called leisure batteries, and him talking to the manufacturers, I was advised to use lorry batteries (4 x 115 amphour) so that is what I did. Got a free engine start battery when I bought the lorry batteries as well! When I was out cruising (4 months at a time) I had an inverter running 24/7 to power a deep freeze, also had a 12 volt fridge working the whole time and even if we stayed in one place for 3 days never needed to run the engine for battery charging. I used to top up the batteries with distilled water about once a month and when I sold the boat at the end of last year the batteries were eight years old and still going strong. So as far as I am concerned so called leisure batteries could be a waste of money - go for normal lead acid ones and look after them.
    Dave
  9. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,921
    10,293
    battery technology has moved on in the last couple of years. Lead calcium batteries have near to double the recharge cycles of normal leisure batteries and some can be used as dual use. Engine batteries will do the job short term but wont last
  10. vwalan
    vwalan Funster
    Sep 23, 2008
    7,674
    3,952
    roche cornwall
    agree totally i find i get lots of years out of truck batteries same as you . have over the years tried alsorts and had friends try different things but truck wet acid does seem to win .
    mine are running an inverter almost 365 days a year. off solar panels .either when away in the truck.trailer ,or at home i run a lead into the house and power house fridge /freezer and a few odd items if its sunny. last batteries 6 years .
  11. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,570
    2,873
    Thanks for all your replies, I will now think and buy. :)
