Leisure batts not charging from engine
Discussion in 'American RV's' started by Mayurua, Feb 4, 2009.
  1. Mayurua
    Mayurua Deleted User
    Hi Everyone
    got some charging issues at moment have had the multimeter out today it seems that the engine alternator is not charging the leisure batteries it charges the starting battery ok. i think i read something somewhere that there may be a fuse somewhere that has blown (fleetwood Southwind on Ford Chassis 1994 . its like looking for a needle in a haystack so before i spend hours trying to locate it i will ask you guys 1st.
    Dave
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,427
    5,457
    East Sussex 01-580-881288
    Try tracing the wire from the batteries back to where the fuse is, sorry not got any better suggestions apart from using the meter on ALL the fuses (if you can find them!)
    Perhaps some one more knowledgable on your van will come along
    Peter
  3. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Isn't there also a relay in circuit that isolates the Leisure battery from the main Battery when the vehicle is parked up so you don't flatten the vehicle battery?
    Just a thought.
    Mine is on the bulkhead in the engine bay.
    Have you a wiring diagram?
    I invested in a circuit tracer a month ago and it's invaluable for this sort of thing. http://www.motorhomefun.co.uk/tech-mech-general/9245-very-handy-test-tool.html
  4. PeteH
    PeteH Funster
    Nov 22, 2007
    2,308
    2,810
    East Yorkshire
    No Charge?
    I had a '87 Pace Arrow, (Chevy 6.2 engine) there was a solenoid (big fat thing, like the old fashioned Starter solenoids) under the front cover which was SUPPOSED to cut off the House batteries until the alternator started charging.
    Two of these "burned out" before I discovered that some previous "twit" had wired it permanently in line and it was constantly connected!!. Mine was fused from the main connector/Fuse box, which if I am right is under the Dashboard? grovel on the back, head under steering wheel!!! to see it!!
    Hope this is of help
    Pete
  5. Mayurua
    Thanks american dream
    When you say relay is it a relay that looks like a relay on a normal car little black cube or one of those big chunky american metal ones ?
    I Wish i did have a wiring diagram going to try and find one in a bit
    As for the wiring tracing tool going to order one right now next job
    Thanks again
  6. TJ-RV
    TJ-RV Deleted User
    Some older motorhomes used to have a diode isolator instead of a solenoid or relay. This is easy to spot because of the large aluminium fins that act as a heat sink.
    Some motorhomes, even today, don't charge the house (leisure) batteries from the engine alternator. Did yours once do that, then stop charging?
  7. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Big chunky thing.Mine is mounted on the bulkhead near the battery.
    Saw one recently on FleaBay.http://cgi.ebay.co.uk/American-Motorhome-RV-BATTERY-DISCONNECT-RELAY-LEISUR_W0QQitemZ250321504124QQcmdZViewItemQQptZUK_Campervan_Caravan_Accessories?hash=item250321504124&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
    Similar to THIS one...
    [​IMG]
  8. TJ-RV
    TJ-RV Deleted User
    That looks a lot like a crossover relay that allows you to start the engine from the house (leisure) battery when the starting battery is dead. If so, this is not the relay that isolates the two battery banks for the purpose of charging.
    I'd expect that crossover relay to be located very close to the batteries with heavy wires going to those large terminals. The charging wires will be much smaller than those large wires.
    OTOH it could be what the description says - a disconnect relay that allows you to shut off the battery from inside the coach instead of using a manual battery switch in the battery bay. We have both the manual switch and the disconnect relay in ours, but neither has anything to do with isolating the two battery banks while charging.
  9. TJ-RV
    TJ-RV Deleted User
    You could contact Fleetwood by email or phone (expensive call) with your coach number and ask where the fuse and relay are. Manufacturers can usually pull up the build sheets and tell you where they hid stuff. OTOH in today's economy, maybe nobody answers the phone or emails.
  10. Camperian
    Camperian Read Only Funster
    Dec 1, 2007
    100
    Dorset - 6months, Spain - 6months
    I have a '95 Southwind and the leisure batts do not charge from the alternator only the genny or on HU. I don't know if a previous owner changed the wiring or not on mine.
    Ian
  11. TJ-RV
    TJ-RV Deleted User
    Ian,
    Our prior Pace Arrow was the same way your Southwind is (both are Fleetwood products). That's why I previously asked Mayurua if his had ever charged and it stopped doing that. Without the answer to that, he might have a long search for the cause :BigGrin:
