Leisure battery
Discussion in 'Tech/Mech General' started by Happycampers1, Aug 28, 2014.
  1. Happycampers1
    Happycampers1 Read Only Funster
    Jun 18, 2014
    71
    29
    St Leonards, Hampshire
    We tried our first "wild camping" today and found that the water pump does not run on battery. Is this normal as it works fine on hookup?
    Also found the fridge doesn't light on gas. Glad we found this out before our winter trip to Portugal.
    Any suggestion?Mike
  2. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Sounds as if your battery's b........, have you got one even
  3. scotjimland
    Jul 25, 2007
    28,994
    25,691
    Suffolk
    as the pump runs from the 12vdc supply when on EHU it sounds like the leisure battery is knackered ( or missing as suggested ) .. test that first and also ensure it is charging ok ... the fridge also requires a 12v supply for the electronics to light on gas..
  4. Happycampers1
    Jun 18, 2014
    71
    29
    Thanks. Already thought of that and put a new 115aH 12v battery in. The lights works fine.
  5. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Isolating switch somewhere? Does the fridge actually spark ,the two could be unconnected
  6. scotjimland
    Jul 25, 2007
    28,994
    25,691
    Suffolk
    New battery but no 12v at pump and probably none at fridge points to the battery main fuse blown .. look for a fuse near the battery .. after that I'm afraid it's a case of tracing the supply cable and looking for it..
  7. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Agree but he says his lights are working
    • Like it Like it x 1
  8. scotjimland
    Jul 25, 2007
    28,994
    25,691
    Suffolk
    hmm so he did.. in that case I'm fresh out of suggestions..
  9. Wissel
    Wissel Read Only Funster
    Sep 16, 2013
    301
    323
    Cornwall
    Strange problem as the pump should run on 12v whether on EHU or battery power. Maybe the pump isn't getting enough voltage when not on EHU to start?
    You could test this by running your engine for a few minutes then trying the pump (with engine still running).
  10. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Depends what he's got, our pump or anything else in the back won't work with the engine running:(
  11. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    Is it a 1996 vehicle ?
    Just thinking, that's a lot of time for some bright spark ( gettit ) to have frigged the wiring.
    Powered from charger and not from battery is pretty difficult, assuming the charger is in fact charging the battery. Make sure you see in excess of 13.5V on your new battery when hooked up or it will be an ex-battery quite soon.
  12. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Are you sure that by coincidence your pump hasn't packed up, have you tried it again on hookup, fridge could be one of many things
  13. Inthezone
    Inthezone Read Only Funster
    Feb 14, 2014
    146
    105
    Berkshire
    Does the fridge work on 12v whilsy travelling, if it does then it suggests there is 12 to the fridge, have you checked the gas burner, has it been serviced the jets are prone to soot build up over time, get a caravan / motorhome engineer who has been qualified to look at it, the pump I cant help with sorry, Have you had the van long and did you get it from a dealer?
    if you did go back and speak to them if not for peice of mind I would have a service done on the fridge and water system, we use a mobile guy who has been in the business 25 years and his charges are reasonable last hab service cost us £80 plus parts
  14. scotjimland
    Jul 25, 2007
    28,994
    25,691
    Suffolk
    sorry.. not correct..there are two 12vdc supplies to a fridge
    The 12vdc supplied to the fridge when traveling via the split charge relay is to supply the heater element only, does not supply the electronics.. The 12vdv for the electronics is a permanent independent supply..
  15. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Thinking about this, why did you put a new battery on , was it because the old one didn't run the pump, or did it not run anything, maybe it was your pump that had give up not your battery, did you test the old battery,
  16. iceni
    iceni Read Only Funster
    Dec 3, 2007
    301
    115
    Birmingham
    My silly mind is thinking that the pump is a 230v pump.
    Mike take a look at the pump itself. there should be a label on with a rating. I wonder if somone has put a 230v pump of some sort in place of the 12v one. We sell pumps for fish ponds where I work but I have known daft buggers run their central heating from them.
    See wha the label says
  17. Inthezone
    Feb 14, 2014
    146
    105
    Berkshire
    I stand corrected :)
  18. TerryL
    TerryL Funster Life Member
    Mar 5, 2010
    1,463
    1,430
    North East
    :eek:I'm thinking if some eejit has done that, I'd want EVERYTHING else on the van checked!:eek:
  19. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    is there a separate switch for the pump that needs turning on, and a fuse for the fridge that has blown. You changed the battery, why did it need changing have you checked the new one is being charged. lights if LED take little power but a pump or fridge ignition requires a decent charge in the battery. What voltage does it read?
  20. chaser
    chaser Funster
    Feb 16, 2013
    8,020
    9,081
    uttoxeter
    Did anyone find out what was wrong
