leisure battery
Discussion in 'Tech/Mech General' started by paulj, May 25, 2012.
  1. paulj
    paulj Funster
    Jul 15, 2009
    36
    12
    South Wales
    I am going to:Wink: add a 2nd leisure battery to my motorhome ,my query is do I need to put an inline fuse on either the positive or negative cable that goes between the 2 batteries and what rating would it need to be any advice would be appreciated
  2. hilldweller
    Dec 5, 2008
    27,190
    26,165
    Macclesfield
    Fuse BOTH ends of positive, so if you get a short anywhere both batteries are protected.
    50A should do.
  3. paulj
    paulj Funster
    Jul 15, 2009
    36
    12
    South Wales
    Brian, this must seem thick but what do you mean fuse both ends of the positive cable:BigGrin:
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,510
    9,938
    a fuse is needed at the battery end of the supply cable. as this is between 2 batteries fuse both ends as close as possible to the battery
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,733
    5,964
    Mansfield,Notts
    Sometimes if batteris are close there is hardly room for a fuse at all I have none on mine because the cable joining the batteries is only 4" long
    However If the batteries are say 3 foot apart a fuse at each end means wherever a fault occurs in that cable a fuse protects it.
    if you only fuse one end. the remaining cable is fed by the other battery and is still live even after the sigle fuse has popped
    Geo
    • Like Like x 1
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,570
    YO11 2BD
    so, i finally broke into the 'common sense' chain :Wink::thumb:
  7. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    679
    388
    Rugby UK
    I have 2 big batteries double decked with no fuse inbetween them, is it dangerous ????:Eeek:
  8. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    679
    388
    Rugby UK
    Can anyone give me an answer ??
  9. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,939
    West Norfolk
    You just need to assess if there is a risk of your positive cable shorting to the vehicle chassis, overheating and causing a fire.
    We do have fuses in our habitation battery charging circuit, but only on those parts of the cabling at risk of contacting the chassis.
    For instance, a bared positive cable will not short circuit the battery by touching wood!
    Of course, having your batteries securely located, cables out of harm's way and protected by additional sleeving and grommets minimizes these risks.
    Hope this best answers your question.
  10. pappajohn
    Aug 26, 2007
    29,903
    17,570
    YO11 2BD
    If the batteries are close together, which your will be if stacked, with a short interconnecting cable and there's absolutely no chance of trapping/chaffing the cables, then it wont be critical to add fuses.
    i have 4 x 110ah side by side in a purpose built battery tray and all wires are on top of the bank so no fuses.
    usually the two, or more, batteries would be some distance apart due to available space and would need a fuse at both ends of their pos cable
    • Like Like x 1
  11. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    i have no fuse.. never have
    I do not have an in line fuse.. never have on any motorhome or RV.
    My two 100 amp batteries are side by side and have a short cable both positive and negative..
    seems a bit over kill to me... I can just imagine trying to fit one:cry:
    Bob:Blush:
  12. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    bob if your batteries are next to each other then there is no need for a fuse as has already been stated however if you had a euro box with its hab battery under the seat and wished to add a second one for example in the rear storage locker then fuses are required to protect the batteries.
  13. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,821
    3,323
    Eastbourne East Sussex
    My batteries are a foot or so apart and are fused. My fuses are 300A because of the inverter. If the fuses are too small you may find you are drawing current from one battery while charging another if the fuse blows without you knowing.
    Theoretically your fuses need to be adaquate for the maximum current drawn divided by the number of batteries. IE if you draw 300A from two batteries in parallel, each battery will supply 150A, but if they were fused at 150A the fuses would probably blow quite frequently so have a bit of margin of safety.
    If you're not running a large inverter then the 50A suggested would be fine.:thumb:
