Leisure battery
Discussion in 'Compass Motorhomes' started by sunni4610, Dec 21, 2011.
  1. sunni4610
    sunni4610
    Jan 10, 2011
    18
    dorset
    Hi every one ,
    my leisure battery mains charged, lasts about 2weeks then goes flat,
    all switches are off, do i need anew battery or is this normal,
    avanguard 200.:RollEyes:
    sunni 4610
  2. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    Sounds like bad news.
    I just came home after 2 months away, unfortunately the van was not on hook up or run at all during the 2 months.
    Leisure battery still at 12.6 volts.
    Callum..
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    you may have something running directly from the battery.....intruder or gas alarm etc.
    if not then i would think about a replacement soon.
  4. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,753
    3,254
    Eastbourne East Sussex
    Disconnect one side of the battery and put a meter across set to measure in the 100mA range. This will show if there is a small constant drain such as an alarm. Even a very small drain will flatten a battery in a week or so.
    In my case at this time of year the low water alarm (tank is drained) uses a bit.
  5. pappajohn
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    just to clarify in case you arent sure.....put the meter between the battery terminal and the lead you took off.
    put it across the battery and you need a new meter instantly :Sad:
