Leisure battery'
Discussion in 'Tech/Mech General' started by Shirley, Jan 2, 2016.
  1. Shirley
    Shirley Read Only Funster
    Apr 30, 2015
    16
    6
    Stockport
    i have 2 leisure batteries, and a solar Panel, and there,s no power going through to the van ? This is our first winter, and not used the van since October, should I have done anything sooner, I have had it plugged into the house electric all day, but nothing has happened. It's afiatdulcato. Any ideas please
  2. f6c
    f6c Funster
    Nov 7, 2010
    3,412
    900
    gloucestershire
    Have you switched 12v?
  3. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,942
    3,401
    Eastbourne East Sussex
    Plug something into a mains socket in the van to check your mains connection is working.
    What is the battery voltage ?
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    New batteries needed unfortunately.
    batteries need to be stored charged.
    Some electronic 'smart' chargers cant detect a flat battery and need 7 or 8 volts minimum to start charging so that could be one reason why it isnt charging.
    If you have another battery try connecting both together, pos to pos..neg to neg, to put some power back in the dead one then put on charge....it may work but i still think the battery is shot.
    I havent used mine for a couple of months, relying on solar to keep charged.
    I forgot to turn on the charger and unfortunately the alarm and tracker took more out than solar put back in (completely dead, no voltage at all).
    turning on the charger did begin a charge but I know, without doubt, it will not hold it and will need a new battery before spring.
  5. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,601
    7,882
    Just make sure you have the electric plug in the side of the van in correctly. So easy not to click it in fully.
    Then check your charger is turned on (light on ?)
    Fuse on the battery is a common problem, check its not blown or loose.
    • Like it Like it x 1
  6. Shirley
    Apr 30, 2015
    16
    6
    Stockport
    Not sure of the voltage, will try fuse in the morning, thanks everyone
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,032
    13,895
    Bolsover, Derbyshire
    My check for mains inside is to look at the fridge, see if the mains light is on, a lot of controllers also have some kind of indication
    but you do also need to check the charger, but it is unlikely to have turned itself off, unless you have a switch inside somewhere
    another point, even if one battery has failed it will drag them both down, I bought 2 new batteries when I only needed one, but depending on the age of yours it may be best to change them both if over 3 years
  8. Targetpaster
    Targetpaster Funster
    Oct 25, 2015
    100
    34
    Devizes
    I have had exactly the same problem. Stored in a warm, insulated, chicken shed. Brand new M/H, 80 miles on the clock! Left on hook up and now flat as...
    I suspect that the power from batteries may be going 'out' when electric supply is off for 17 hours a day as storage owner only has supply on between midnight and 7am (tariff). For you techies then.. Is that likely do you think?
  9. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,398
    5,659
    Guisborough
    7 hours a day should be more than adequate to keep your batteries on top form, are you talking about the habitation or your vehicle starter battery as not all charging systems include the vehicle battery in the charging regime from hook up. If talking habitation batteries you need to check the charger is switched on, what voltage do the batteries show when the charger is on. If they are flat flat they may well be damaged beyond rescue.
    Martin
  10. Shirley
    Apr 30, 2015
    16
    6
    Stockport
    Hi Martin n Jen, had my leisure batteries checked today, and they are full, also the fuses are all ok, it seems there,s no power getting from batteries to the lights etc, very strange
  11. Targetpaster
    Oct 25, 2015
    100
    34
    Devizes
    Engine battery fine. When I left van a couple of weeks ago it was showing 12.3 and I left it with absolutely no little lights etc showing anywhere! RCD was in the right position and charger was on . You're probably right about 2 kaput leisure batteries. Very irksome considering MH is brand spankers. Not even spent a night in it! Doesn't give me very much confidence in the system
  12. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,794
    4,268
    Newbury , West Berkshire
    Shirley,without putting a too finer edge on it,how many threads are you going to start with the same problem ?? I think you must be a little confused as to how to respond to the answers the people are are trying to give you..they like me are trying to follow and help you resolve th problem you have with your van .
  13. Shirley
    Apr 30, 2015
    16
    6
    Stockport
    You re right, havnt got a clue, sorry to be a pain xx
  14. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    We are trying to help you, but if you just keep to one thread it makes it easier. Did you not find an auto electrician to help you?
  15. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,794
    4,268
    You only have to post your reply in the box underneath the response as you have just done and click on "post reply" simples.!!
  16. Shirley
    Apr 30, 2015
    16
    6
    Stockport
    Thank you I think I've got it now, it ll be weekend before auto elec will come, but I can wait, hope it's something simple, will let everyone know, in case it happens to them, thanks again for all advise,
  17. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    Hopefully just a case of replacing leisure battery, hope you get it sorted quickly and cheaply. :)
  18. sallylillian
    sallylillian Funster Life Member
    Oct 29, 2011
    978
    596
    Falmouth, Cornwall
    12.3 is very low, engine battery is not fine.
  19. Targetpaster
    Oct 25, 2015
    100
    34
    Devizes
    That was the voltage shown on control panel for leisure batteries not engine.
  20. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,723
    23,138
    Narrfoook
    The system in our Autotrail is a Sargent
    The voltages showing on the control panel always read .4v low
    Even tried a new panel but got the same readings
