leisure battery (1 Viewer)
pops
544
697
south glos
Pilote panel van
since1997
Hi Steve, Is there any lift up covers in the floor, that's where my 2006 Kon tiki hab battery was located.
DanielFord
3,020
3,086
Is that the one with the washroom at the rear, and the centre dinette? I would look under the sofa on the left (looking backwards). you will probably see a black lift out panel/trapdoor, should be under there. Also possible as above, that you have a lift out panel on the floor just in front of the bathroom.
If not, wait until it is a bit drier, then lie under van, and look at the floor, you should be able to see a hanger somewhere that contains the battery, this will give you a clue where the access is inside the van.
angusboy
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
Hi guys yes it is end bathroom will check out on thursday when go to van , and thanks again guys
