Leisure battery venting
Discussion in 'Tech/Mech General' started by micky drip, Jan 15, 2013.
  1. micky drip
    micky drip Read Only Funster
    Jul 4, 2012
    190
    121
    mid wales
    Can any of you funsters tell me where I can get parts to make a battery vent. I need an elbow to fit into vent hole at the top of the battery, also a bung to seal the vent at the other end of battery and tube to fit the elbow.
  2. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,759
    3,258
    Eastbourne East Sussex
    It could be worth looking in an aquarium shop as similar sized tubes are used for aerating fishtanks, otherwise the supplier/manufacturer of your battery.
    • Like Like x 1
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    No idea where you will get ' proper' parts but this may get you out of trouble.
    windscreen washer jet plumbing.....
    any motoring shop will stock the T pieces, 90 deg elbows and tubing.
    if you cant get an elbow just cut off one ' leg' of a T and seal the open end with a little araldite.
    if the plastic elbow/T is too small for the hole then use a little more araldite to glue it ln....dont get any in the T piece.
    again using araldite, fill the hole at the opposite end of the battery.
    • Like Like x 1
