Leisure battery - replacing with solar panel.
Discussion in 'Tech/Mech General' started by savantuk, Jun 11, 2011.
  1. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    37
    Cumbria, Lake district UK
    Hi,
    Just a quick ne for the electrical experts.
    I'm going to change my leisure battery for a new one, and I'm wondering if all I need do is to disconnect the old one, and fit a new one??
    Any special precautions?? I know that the terminals will be live because of the solar panel.
    Should I leave it to a dealer?
    Thanks,
    Doug
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,108
    17,778
    YO11 2BD
    no special precautions....just ensure the pos lead doesnt touch earth and all 12v stuff is turned off....tv etc...as the solar panel may output up to 17v when no battery connected.
    better still...do it after dark, no solar charge then :Wink:
  3. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Help!
    The lights gone out!!
    I can't see a thing!!!
    Doug...
  4. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    Its all a pack of lies fed to the masses by a wicked government to condition the masses into swallowing the their cuts and taxes so the rich can become even richer.
    :Rofl1:
    • Like it Like it x 2
  5. icantremember
    icantremember Funster
    Sep 2, 2010
    5,396
    7,498
    Nr Watton in Norfolk
    You could also just cover the solar panel to keep the light out........then you would at least be able to work in daylight!
  6. Gonewiththewind
    Gonewiththewind Read Only Funster
    Sep 13, 2007
    854
    35
    Lancashire
    Why not simply remove the fuse from the charge controler unit.:Eeek:
    Don
    • Like it Like it x 1
  7. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Go to your solar panel regulator and disconnect one (not both) of the wires from the solar panel.
    Then the charge isn't getting to the battery so no problem :BigGrin:
  8. pappajohn
    Aug 26, 2007
    30,108
    17,778
    YO11 2BD
    did nobody notice this then ................................. ^
    :Rofl1: winking smiley = just kidding, tongue in cheek. :Doh:
  9. SandJ
    SandJ Funster
    Sep 14, 2007
    1,594
    553
    North Yorks
    Bryan
    Not sure if all regulators are the same but mine say's remove the battery wires first and replace battery wires last, this must protect the regulator.
    Also
    There is a large fuse at my battery which if the ops has the same i would remove that.
    :thumb:
  10. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,940
    3,400
    Eastbourne East Sussex
    According to Detroit solar who fitted mine you must disconnect the panel from the controller before disconnecting the battery as the relatively high voltage and current from the panel can damage the controller. There is usually a fuse you can remove, or alternatively as suggested earlier, cover the panel.
  11. SandJ
    SandJ Funster
    Sep 14, 2007
    1,594
    553
    North Yorks
    I have just done a Google search for which to remove first and have found both are said to remove first :Eeek:
    My regulator instructions clearly stated remove battery first and replace battery last.
    So what to do?
  12. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    On my regulator which has a relay switch to turn the charge off and on, removing the battery first makes the relay chatter. It would seem that regulators are not all the same.
    Doug...
  13. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    No. I can't read hieroglyphics.
    Doug...
