Leisure battery renewal
Discussion in 'Motorhome Chat' started by felix1047, Sep 12, 2016.
  1. felix1047
    felix1047 Funster
    Jul 13, 2016
    7
    Wrexham. North Wales
    Hi.I have a 2006 B614 Hymer. It is fitted with 2 G80 Exide gel batteries from new. I recently read a blog on the VARTA LFD90 battery which at around £80+each seems a much cheaper option. Does anyone have any experience of these.
  2. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    2,130
    5,358
    Langtoft, South Lincs
    Are your Exide's dying?
    Is your Hymer's charger set to Gel
    The Varta batteries you mention are "wet" batteries so a different beast to the Gel ones you have. Apples & Pears.
    • Like it Like it x 2
  3. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,269
    1,340
    Dronfield - Derbyshire
    There should be a setting to change the charging for different types of batteries
    • Like it Like it x 1
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,994
    Warwickshire
    I have had 2 x Varta LFD90s since April 2015. They replaced 2x110 Ah Elecsols (wet lead-acid) which lasted 6 years and they, in turn, replaced the original 2 x 80 Ah Exide gels that were the original equipment and also lasted 6 years.
    So far, the Varta LFD90s seem very good - hopefully they will last as long as their predecessors. The van is a Hymer B630.
    The gel batteries have the advantage of being able to withstand deeper discharge, but the disadvantage of taking much longer to recharge than wet lead-acid. They are also more expensive of course, but can be bought for around £150 or a bit less. Now called ES900 rather than G80.
    If you decide to buy the Varta batteries, don't forget to change the setting on the EBL selector switch, from 'blei-gel' to 'blei-saure'.
  5. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    When I replaced the two Gels on my B644 .. as far as I could determine, they were original Hymer fit ..
    I was never a Gel fan.. but these were now 14 years old.. and still working.. I was impressed..
    so, I decide to replace like for like with ES900 Exide G80 from Tanya ..
    When I removed the old ones, I bench tested them.. one was goosed, not holding a charge .. the other was ok, so I kept it for bench testing 12v kit
    I paid..
    £149.90 each
    P&P £15.19
    TOTAL £315.00
    they have come down in price ..
    now £134.91
    https://www.tayna.co.uk/ES900-Exide-G80-Marine-and-Multifit-Gel-Leisure-Battery-P7693.html
    I am more than happy with the performance.. we seldom use EHU, I have 2 x 80w solar panels which keep them charged..
    just to ensure they are properly maintained.. I put them on charge at home.
  6. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,881
    6,016
    Guisborough
    I would also ask "is there anything wrong with the G80's" that Hymer originally fitted to your van, we are still using ours from 2006.
    Your Hymer should be set for Gel batteries as it was built to use them (not all vans are) if you are going to change why would you not fit batteries that have lasted 10 years as not many do.
    Martin
  7. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    253
    109
    Sussex
    If you replace with Varta LFD90, remember they should be vented if located in a confined space.
    The batteries in my previous Hymer were located beneath the two front seats. If yours is the same, then it would be wise to vent them.
    Earlier this year I fitted 2 x Varta LFD90 and they seem to be performing very well. They were installed in the double floor area so needed to be vented.
  8. felix1047
    felix1047 Funster
    Jul 13, 2016
    7
    Many thanks for all the replies on this. Am I correct in saying that if I opted for the Varta Battery I would have to reset the nominal capacity in the control panel as the Varta ah is different to the Exide.
