Leisure battery question - mixing Ah? (2 Viewers)
Xan
158
102
Bristol
I'm new
Our MH has two leisure batteries. The handbook says to use 85Ah batteries, and both batteries are 85Ah.
I'm testing them at the moment, but if one needs replacing is there any reason why I shouldn't use a higher Ah type?
chatter
3,689
937
cheshire
5th wheel
Idearly you would replace as a matched pair, if one battery is not as good as the other, the worse of the two would pull the good battery down, the same as if you put two different amperage batteries on you would only get to 'fully charge' in situ as high as the lower rate of the two batteries
rainbow chasers
3,680
1,725
Mid Cornwall
Various
It is one of those grey areas - the reason being, that many 80ah batteries are actually relabelled 110ah. It has become common practice to relabel the larger batteries as they are cheaper to manufacture in bulk.
scotjimland
2,303
9,970
A Woosh bang
It is one of those grey areas - the reason being, that [HI]many 80ah batteries are actually relabelled 110ah.[/HI] It has become common practice to relabel the larger batteries as they are cheaper to manufacture in bulk.
Really . .how do you know this.. ?
if this is happening surely a case of fraud .. also.. how can it be a 'grey area' , fraud yes but grey ?
Jun 2, 2010
4,924
11,289
Flintshire
Low profile
since 2010
That's what I was thinking, in actual fact I thought the punch line was going to be the 110's were relabelled as 85's:RollEyes:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
I think RC has read the same advertising blurb as me a few months back- I am not sure if they have changed how they label amp hrs on battery's but he has got the jest of it right.:thumb:Some are labeling batts at say 110 amp hrs when on the new system they are only 100 amphrs -not sure how it works as I was not that bothered at the time ::bigsmile:Still not :winky:
terry
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Sorry but both battery's would keep on charging until they both reached there peak IE 85 and 110 amp hrs your charger will only see the pair as one 195 amp hrs battery :thumb: Not arguing that it would be better to fit a matching pair ::bigsmile:
terry
X
Xan
158
102
Bristol
I'm new
Well, the 85Ah Numax's that are installed are showed 12.8v and 12.7v respectively after about 10 hours on the hook up yesterday.
I've checked them again, some 24hrs later and both are showing 11.9v.
They're not sealed, so I'd like to check the fluid levels and do a hydrometer test before deciding to replace. Which brings me to my next question / challenge.
How on earth do you remove under cab seat batteries? Do I have to remove the seats from their mounting plinths?
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
after only 24 hrs,At 11.9v both are creamcrackered::bigsmile:
Terry
Edit yes remove seat
Minxy
32,641
66,519
E Yorks
Carthago Compactline
Yup - but be warned they are HEAVY!!!
43,320
49,404
Taken from a previous post by me...
Quote:
Originally Posted by loubsterlouise
Well for a start I was led to believe that batteries only charged to the lesser or weaker one so why connect all 3 if 2 have larger capacities.I wouldn't know where 2get bits from or what bits required.Finally not very confident with electrics and with 2small kids wouldn't want to get it wrong.
then you were lead to believe wrongly.....a myth.
you can connect any sized battery to any other sized battery without problem. (parallel connection in this case)
the only time it really matters is if one battery is beyond help.....or is a different type...gel, AGM etc.
a simple example.
take a sink basin, a washing up bowl and a large jug.
basin = 125ah battery, bowl = 100ah battery and jug = 75ah battery.
now stand the jug in the bowl and the bowl in the sink and start to fill the jug.
once the jug is full the water will overflow into the bowl and in turn the bowl will overflow into the sink.
all three are now full.
same applies to batteries.
once the 75ah is full it wont take any more charge but the charger will continue to charge the 100ah until that is full, then it will continue to charge the 125ah until that too is full.
you will then have one large battery of 200ah capacity.
the charger doesn't 'see' 3 batteries...only one 200ah battery.
if one battery is faulty or old it will then impact on the total capacity...it wont take/hold a full charge but the two good ones will still be fully charged but will show an overall reduced capacity due to the duff battery..
43,320
49,404
dont know about the newer Fiats/peugeots etc but the older ones have two bolts at the front of the runner, on the front face of the seat plinth, and a further two torqs bolts inside the runners at the very rear of the runner...seat needs to be right forward to access the rear bolts.
and the seats are very heavy for what they are.
Pigwam
45
8
Chester
Since 2011
I have assumed I have read this wrong, it used to be common practice to relabel batteries at different hourly rates eg 28ah @ c5 hour rate would be relabeled 36ah @ c20 hour rate depending what use it was going to be sold for, but not the other way round just look at the price of lead.
the first thing you always do if you suspect a battery has been labelled a higher capacity than it should be is to weigh the battery and I can assure you that different capacity's even 5ah will weigh in at different weights. and check the battery spec from the manufacturer.
If batteries are over 12 months old always change them as a pair.
its not good practice to use batteries in parallel or of different capacity's for al-sorts of reasons, but we are limited for space normally so its an easy option.
X
Xan
158
102
Bristol
I'm new
Well, the seats have been removed and the two batteries taken out until their replacements arrive tomorrow.
Only 4 bolts per seat to remove, but of course front and rear are different types and sizes.
Rear 6mm allen no nut, front 5mm allen with nut. To get at the nuts on the front bolts, the plinth sides have to be removed. :RollEyes:
A right kerfuffle........
Broken Link Removed
................I don't like it.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
No It was me! I typed the wrong way around - 110 relabelled as 85's it should have read!:Doh:
Battery supplier informed me of this a couple of years ago, as it was cheaper to manufacture the 110 in greater bulk than the 85 and 110 separately - so in effect, those buying 85's MAY get a better battery depending on source.
X
Xan
158
102
Bristol
I'm new
Is that really likely? Given that 110's are generally bigger due to having more plates?
rainbow chasers
3,680
1,725
Mid Cornwall
Various
That was what I was told when ordering leisure batteries, that it was best to go by physical size (there are lots of different dimensions) rather than capacity. Indeed when replacing the last one, with a labelled 85ah, it was a good three inches longer and maybe half inch taller than the original, and did look more like the size of a 110 - which it probably is in reality. Fitted in though - just!
We now always take dimensions rather than capacity to size like the old days, when it was uniform unless it was an import vehicle.
Pigwam
45
8
Chester
Since 2011
While not wanting to cause an argument i think its very unlikely that a manufacturer would do this and after 20+ years of independently testing batteries I've not come across this, read my previous reply which was the only thing i could think of is hourly rates which can make a difference.
more plates doesn't mean a bigger battery, its normally fewer plates that make a better battery for leisure use, eg 11 plates more lead good for traction while auto batteries have more plates less lead but very good at cold start, again as i said before always look at the weight of the battery.
X
Xan
158
102
Bristol
I'm new
So, I have now received and installed two new batteries and re-installed the seats.
The new batteries had small bungs on each side, and these are to be removed before charging. As the MH has battery vent pipes should I connect a vent pipe to each battery and leave one side of each still blocked with a bung?
43,320
49,404
correct, the battery has two bungs to allow fitting in awkward spaces where only one, or the other, vent is accessible
