Leisure battery problem (1 Viewer)
georgie boy
143
15
liverpool
Concorde charisma
Hi just asking some advice about leisure batteries we have 2 fitted on our motorhome which we purchased around 2 years ago which were heavy duty deep cell. About 2 weeks ago we found the battery power wasn't lasting very long so decided to take the battery out to inspect them. When we got them out found that one of them had a very large crack down it's side which had leaked the acid out. So decided to clean up the crack and botch it up with epoxy resin the refilled the battery with distilled water. So then put it back on the van and put them on charge via the electrics on a campsite . They took a full charge But after about a week they began to die very fast when we put tv ect on. So took them out again only to find the one which I repaird was empty of acid again. So decided it was time to renew them. The problem being do we replace the damaged battery with the same make and size battery or would this make a problem because the battery on the van would be a lot older or do we get rid of the 2 batteries and replace with one large 220 leisure battery ?
JockandRita
11,402
148,470
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi there,
Personally, I'd be renewing either both batteries, or replacing them both with one very large battery.
If you only replace the damaged one with another of the same capacity, the older one will drag the new one down, as I understand it.
Our 3 x 100 amp batteries will all be replaced together, as a complete bank, when that time comes.
HTH,
Jock.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Yup.... agree with Jock
Change both or get one larger one ( but check if it will fit in your battery compartment)...:thumb:
pablomc
772
237
Durham
Since 2009
Replace both. Whether you get two (same type as each other) or a single then that is down to personal choice although there are pros and cons of both.
As a side note and I don't want to sound condescending and apologise if it comes across this way, but you should never attempt to repair a battery. The battery could have easily exploded. Any battery with a crack or even just a bulge in the casing should be replaced. It is just not worth the risk or additional cost in the aftermath.
JJ
Mágica
May 1, 2008
19,228
47,725
Burstner Privilege T
over 50 years
Just bought some 120 amp hour batteries from Frank's Caravans at the Newbury Show... advertised price £89.90 but I think he will do a deal for Funsters. (He did for me... but then I bought seven!)
They will be at the Stratford Show.
JJ
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
By topping up the split cell, you have effectively diluted the electrolyte, hence no capacity!
Battery replacement is the only solution unless you have an Iranian friend who has just has his proposal for marriage turned down and might have some suphuric acid going spare............!::bigsmile:
43,207
48,809
if anyone attempts to repair a battery and has access to sulphuric acid.......never, ever, under any circumstances add acid to distilled water...the reaction will be violent and acid will be thrown everywhere.
always pour water on acid....never acid on water
if the battery is split, then it split for a reason....usually because it froze but occasionally by severe overcharging.
it will be knackered anyway so just replace it.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
JJ
was the iveco a milk float before you got it JJ:ROFLMAO:
pudseykeith
382
105
Leeds West Riding of York
6 Years
Just a point Georgieboy, where did the acid that leaked out go. If it was not washed off it will cause a lot of damage and rot and need attention.
pudseykeith.
