leisure battery problem
Discussion in 'Motorhome Chat' started by gazza50, Feb 9, 2010.
  1. gazza50
    gazza50 Read Only Funster
    Feb 9, 2010
    3
    HI IM JUST WONDERING HOW TO CHARGE MY LEISURE BATTERY FROM MY GENERATOR AT THE MOMENT THE LEISURE BATTERY IS TAKING CHARGE FROM THE VAN ENGINE BATTERY BUT I WANT TO USE MY GENERATOR TO CHARGE THE LEISURE BATTERY ANY IDEAS ANYBODY THANKS GARY:Sad:
  2. robinmclaren
    robinmclaren Read Only Funster
    Feb 23, 2009
    345
    32
    coventry , warwickshire
    i assume you have fitted a split charge relay so van batt does not drain when engine off.
    if so leads from genny 12v to battery
    if no 12v on genny , then genny to a battery charger , to battery
  3. gazza50
    Feb 9, 2010
    3
    Yes
    YES THANKS MATE DIDNT THINK OF THAT JUST UNPLUG FROM THE VAN BATTERY AND PUT A BATTERY CHARGER ON THE LEISURE BATTERY AND THE CHARGER FROM THE GENERATOR IS THAT WHAT YOU MEAN :BigGrin:
  4. robinmclaren
    Feb 23, 2009
    345
    32
    yesif you have no 12v on genny
    you should have a relay inbetween engine battery and leisure battery to stop engine battery discharging when engine off , very simple 30a relay switched on from ignition feed
    shouldnt need to disconnect battery as will not damage anything while being charged
  5. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,468
    881
    South Glos
    Hi Gazza,
    What sort of van have you got? Has it got an on board charger for keeping the battery charged when on Electric Hook Up? If so just connect your gennie to the EHU and select the leisure battery on the control panel.
    Lunarman
  6. robinmclaren
    Feb 23, 2009
    345
    32
    i had assumed from you post you have a very simple conversion with no chargers onboard , if i am wrong then agree with above post and just plug it in as mains
  7. SandJ
    SandJ Read Only Funster
    Sep 14, 2007
    1,558
    518
    North Yorks
    have
    If you have a commercially modified van, you could use a plug straight from charger to the plug you use to connect 240v.
    Always start up charger before connecting and do not have any load on 12v when you connect charger
    :thumb:
  8. gazza50
    Feb 9, 2010
    3
    well i just bought this van and its a catering van which as a leisure battery running of the van engine but what im scared of the leisure battery runs the fans in the roof which need to be on 4 hours all the time and im scared it going to drain the engine battery because i dont want to have the engine on when serving ,so im thinking use the power from the generator instead of the engine hope you understand what i mean ,
