Leisure battery help pls (1 Viewer)
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
What a great forum, like having a big brother/sister to ask when stuck, guess it was in the dealers and pay before this.
Anyways my new leisure battery seems to go flat after only 3-4 days when parked at home with nothing running, alarm off etc. I know the dormant vehicle soaks some 12v but this seems rubbish to me or is it ?
I changed the battery as a matter of course as was 2007 so thats eliminated and I even charged it in the cetek before fitting it.
As usual all thoughts great fully received.
Terry
11,903
8,969
Lincolnshire
Can't remember ;)
hI, YOU ARE GOING TO HAVE TO INVESTIGATE-SOMETHING IS ON PULLING THE POWER:Smile:(bloody caps::bigsmile:) LB should keep charged until you turn the power on -are you turning it off? before storing?
terry
pvw10
pvw10
273
45
Gloucester
Coach built
terry
Hi Terry,
Ran on site on mains for three days then can home, 3 days later showing 3.2v Oh Please!.
If I leave lb on its fine but lb seems to run hot and fan hardly ever stops so tend to turn it on as and when battery low ?
Terry
11,903
8,969
Lincolnshire
Can't remember ;)
Hi Paul, you have me confused but that doesn't take much ::bigsmile:
Do you turn everything off at the control panel when leaving the van?
You mention only having 3.2v in LB after acouple of days, if thats the case then I suggest you get LB checked out (it's knackered) yet you say it's new.It shouldn't ever drop below 12v and stay that way if it does then as above K ed
Try decoupling battery terminals charging it and see what you are reading after disconcerting and next day after leaving it standing then get back with readings
Terry
pvw10
pvw10
273
45
Gloucester
Coach built
Terry
He he sorry no battery is new lb original. Yes all turned off and 3-4 days goes to almost flat.
I have ordered another charging lead and will fit a second battery but the drain is a worry.
Does your lb get quite warm with the fan on all the time as I'm sure my apache didn't but it was in a footlocker so not sure.
43,202
48,793
even if your battery wasn't knackered, it is now.
A battery cannot drop to such a low voltage, even for a short time, and survive.
As it was new I suggest it was faulty from the outset and needs returning under warranty.
Also check the output of your on board charger with a multi/volt meter....it might not be working.
pvw10
pvw10
273
45
Gloucester
Coach built
Hello again fella, good to hear from you again.
Battery is ok, cetek gave green light after an overnight charge.
Charger works ok as when turned on its throwing about 13.4 ish out so feel battery is being pulled down rather than charge/battery ?
43,202
48,793
ok, you have something dragging it down then.
Even a light load of 1amp will pull it right down over 4 days.
A 1amp load over 96hours = 96amps.
Check for the obvious, but easily overlooked things, like a single locker or cupboard light for example.
Charge then disconnect the battery, leave a couple of days then check voltage.
As said, the battery is probably buggered now due to the previous severe discharge level but worth a try.
If it does hold a charge then it illiminates the battery as faulty.
pvw10
pvw10
273
45
Gloucester
Coach built
Good shout thanks I will do that.
Does your fan run most of the time on your charger ?
She is having 4 new tyres as we speak, michelin campings 2006 vintage sidewalls are shot, 12000 miles only. Not having those on that's for sure.
43,202
48,793
the fan on mine only comes on near the max charge current....which on mine is 45amps.
Most of the time the charge current is low so the charger isn't doing enough work to need cooling.
But that also makes me think you have a faulty battery....the charger is really working near, if not at, its full capacity to charge the battery...and it shouldn't need to.
once some charge is absorbed into the battery the current begins to reduce as the volts rise so it runs cooler.
pvw10
pvw10
273
45
Gloucester
Coach built
Mmm my thoughts also.
If you see an earlier thread on battery leads i have ordered a Sargent lead and have a brand new battery so plan to add this, and disconnect the one in situ, that should prove it out ?
Terry
11,903
8,969
Lincolnshire
Can't remember ;)
You keep insisting new battery, both myself and john have suggested giving it a charge then leaving it disconnected over night and take a reading next day or day after that way you illiminate the battery
Terry
pvw10
pvw10
273
45
Gloucester
Coach built
Yup guys I think we concurr the new battery is pants, when the other new one is in it will prove it out.
Thanks again.
pvw10
pvw10
273
45
Gloucester
Coach built
Terry
Just spotted how I confused you although I thought I was clear ish.
There was a New battery fitted in camper when recently bought, this is suspect one. I have just bought new leads from Sargent and a second brand new battery. It is this battery I will use to test system, the other to be removed and checked as suggested.
Terry
11,903
8,969
Lincolnshire
Can't remember ;)
Hi Paul, right with you now :Smile:fit new battery take reading then leave over night and take reading but make sure everything is turned off at control panel. There should be nothing pulling the battery down :winky:
Terry
pvw10
pvw10
273
45
Gloucester
Coach built
Terry
Roger that will do, battery bringing home from work tommorrow so can so quickly but will put on Cetek for 24 hours first to ensure in a good state.
Just also awaiting Sargent lead, the one I received has wrong plug on annoyingly.
pvw10
pvw10
273
45
Gloucester
Coach built
Well my little battery Ninjas so far it's,
Brand new battery on cetek and all fully charged, fitted in camper and display says 12.7v with nothing turned on so let's see what 24 hours brings.
The removed suspect battery is on the cetek out of interest and either taking a very long time to charge or is duff, I'm hoping duff then as you guys said this proves the battery is a duffer.
I will advise on e there is news.
pvw10
pvw10
273
45
Gloucester
Coach built
Looking good chaps.
New battery installed display said 12.7, 48 hours later 12.4 which I think is great, you guys ?
Funny thing the suspect battery I stuck on the cetek and it charged and got very hot then after about 15 hours it went to Green!!
Seems like ( sounds daft) the battery had a blockage which the van charger couldn't pass, is this possible ?
I have a bulb on this battery to fully discharge it then I will cetek it again to see if scrap/good but measures 12.7v.
Apr 27, 2008
11,788
13,942
Eastbourne East Sussex
Hymer low profile
Since 1972
Looking good chaps.
Don't fully discharge the battery as that will kill it even if it isn't dead already. A battery should only be discharged down to about 12.2v which will be around 50%, anything below this will damage it.
edit : Don't rely on the voltage on the panel until you have checked it against a reliable meter, they aren't always very accurate. Mine reads 0.5V lower than actual, which is fine as long as you know how far out it is.
Scout
3,955
119,774
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
just a though, have you got a light in some under floor locker that MAY have been switched on? on my m/h there is such a beast and the switch is right next to the door step switch, somebody (who shall remane nameless but is not me) gets then mixed up
Terry
11,903
8,969
Lincolnshire
Can't remember ;)
Looking good chaps.
you have something on :Eeek:
:winky:
terry
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
I'm old fashioned, don't have a satellite system in the van, but do have a terrestrial aerial, this has an amplifier fitted. If its on over night my leisure battery goes down 20%, if its off about 5%.
Look for little led lights somewhere.
Peter
