Leisure Battery "Earth"
Discussion in 'Motorhome Chat' started by horshamjack, Oct 20, 2014.
  1. horshamjack
    horshamjack Funster
    Apr 23, 2014
    465
    598
    Southern Europe
    I recently installed 2 110Ah leisure batteries in place of the 85Ah that was originally installed
    The only wires that were connected to the battery were thin prob 4 gauge 2 red 2 black? Which I assume come from charger and the alternator B2B ?
    I used 25mm cable to parallel them up
    My question is do I need to fit an earth strap from neutral to chassis ?
    The original 85Ah battery did not have one fitted
    Your thoughts and answers appreciated
  2. scotjimland
    Jul 25, 2007
    28,935
    25,617
    If it is working ok without the negative strap to the chassis, adding a second battery doesn't fundamentally change anything.. the load on the cables doesn't increase, but it would do no harm to fit one.
    Personally I wouldn't bother.. others may say differently..
  3. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,748
    11,614
    Taunton Somerset
    When you say B2B do you have an aftermarket B2B? Or are you referring to the "Split charging system" fitted by the manufacturer?
    If the latter I agree with Jim, if the former, it sounds all wrong
    Eddie
  4. horshamjack
    horshamjack Funster
    Apr 23, 2014
    465
    598
    Southern Europe
    Yes it is the split charge fitted by the manufacture ,
  5. eddievanbitz
    Oct 4, 2007
    3,748
    11,614
    Taunton Somerset
    Jim is spot on, if it's not broke, don't fix it. You see no appreciable improvement by tinkering, you'd have to change a lot to see any real difference
  6. horshamjack
    horshamjack Funster
    Apr 23, 2014
    465
    598
    Southern Europe
    Thanks for your replies
    So am I right to think this is called a floating earth ?
    It just made me wonder why the engine battery is grounded and not the leisure ?
    But as Jim pointed out everything works and since the installation of the 2 new batteries and fitting of 2 x 100w solar panels my batteries are holding their own fine
  7. scotjimland
    Jul 25, 2007
    28,935
    25,617
    I wouldn't think it's 'floating' .. just not grounded at the battery.. but if you are interested to find out, easy to check with a multimeter..
  8. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,953
    1,697
    Bungay Suffolk
    Yes, as said put a multimeter on it and check continuity to earth from the neg terminal..
    • Like Like x 1
