Leisure Battery draining (1 Viewer)
Clickem
1,034
1,073
Northumberland
None
7 years
We have a 2013 Auto Trail Trivago Tribute on a Transit chassis, and after standing for a few days, the Leisure battery is flat. The battery has been off the vehicle all winter, is in good condition and the problem has just started. As far as I know everything electrical was turned off and when I turned the Control Panel on and selected Leisure battery the low voltage (<9volts) alarm went off, and voltage measured across battery terminals with a meter confirmed this
The Power Supply unit is a Sargent EC155 and the Control Panel is an EC51
Broken Link Removed
With everything electrical turned off, including the Control Panel, a bulb connected in series into the battery cable glows and I think the current flow measurement is about 0.2Amps, or 2.5 Watts of power
I have removed fuses from the Power Supply unit, in turn, and the 2 fuses that stop the current flow are
1. No 8 - A 5 amp fuse marked "Permanent Supply" (Radio/Fridge)
2. No 10 - A 20 amp fuse marked "Leisure Battery"
The Dometic fridge appears to work on Fuse No1, which is also marked fridge (non compressor type) and the fridge is not effected by fuse No8 being pulled. I assume the reference to radio, is if a radio was fitted in the habitation area, as the cab radio is the standard Ford unit and is powered from the vehicle battery
I am fairly certain that all electrical items are turned off, and assume that if the Control Panel is off, then they get no power anyway. I will have another look inside after dark in case any light shows
Sorry for the long explanation. Please can anyone suggest any reason for the current drain and the fairly rapid battery discharge, or a visit to the dealer will be needed
TIA
RowleyBirkinQC
2,346
225,813
Dazed & Confused
We had a similar issue with our 2006 Autotrail Tracker, transpired to be the reversing camera/screen permanently drawing power if not isolated via the switches in the cupboard where the Sargent EC200 and entertainment system reside. I think the same scenario was also reported by another forum member, but I've no idea this could also be your issue.
43,301
49,289
With a drain that high and fremoving the fridge fuse stops it i think you answered your own question......the fridge 12v relay is stuck closed....though why it should be draining the hab battery is a mystery, it should be wired to the engine battery.
Reactions: f6c
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
We have a reversing camera. I would have expected it to have been wired through the ignition, but I have just checked and it is powered from the Leisure battery
I was wondering if it is only a problem when the vehicle is parked in reverse, but unfortunately not
Thank you very much for the pointers
43,301
49,289
Ignore the above post....just read your post again.
Pulling fuse #8 removes the load Its obviously something on fuse #8 and pulling fuse #10 effectively removes the battery from circuit so will have the same effect
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
The reversing camera and screen are wired through fuse number 8, an accessories fuse, and therein lies my problem
Many thanks
andy63
4,672
15,017
south shields
None
since 1990
Hi had a quick look and I suspect your radio is powered via the leisure battery..It would explain the drop in the drain current (200ma.)you mention when you pull the fuse..
You seem to indicate that you don't think this is so and is off the vehicle battery..and that may be the case but worth checking.
However that drain shouldn't flatten a fully charged healthy battery in two days . There has been something else drawing more current or the battery wasn't in a good state of charge or condition......but you said it was so you are back to finding the higher current drain....
Hope you get sorted ...maybe someone familiar with your set up may be of some help.
Ta andy
andy63
4,672
15,017
south shields
None
since 1990
Lol ignore that see you are sorted...(y)
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Years ago I fitted an isolation switch for the supply to the camera, I noticed that the infra-red led's were lit at night. Sorry but I can't remember the draw on the battery but it did flatten it in three weeks.
