Leisure Battery discharging (1 Viewer)
PaulP
Kent
Low profile
I have a Rapido 741f m/home. The battery is discharging when nothing is switched on .New battery fitted
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
Have you got an alarm.
Also is the heater fan on even slightly if it's a Euro van?
457
3
You will find that there is always a minor discharge and it is recommended that you give it a charge up every now & again.
American Dream
156
Lincoln
The alternator regulator discharges the battery, albeit by a very minor amount.
You will notice a vary small spark as you connect the battery leads.
The way to prove what's causing it is to put an ammeter (multimeter) in current (amps) mode.
Connect the -ve cable of the van to the battery.Leave the +ve lead off.
Connect one lead of the meter on the battery terminal and the other on the positive lead.This should show the discharge.If you get a negative reading on the multimeter reverse the leads from the meter.
Systematically disconnect all electrical equipment.
It sounds as if it's an alarm or demobiliser.
You haven't left the 12volt fridge on have you?
You did not give a time scale that the battery discharges over.
3,985
6,246
Rochester
Auto-Trail Mohawk
16 fun filled years
It's the leisure battery, the alarm or alternator should not be the cause of a discharge surly.
