Leisure Battery connection help
Discussion in 'Motorhome Chat' started by con-tiki, Jul 26, 2012.
  1. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    Leeds, West Yorkshire
    I want to add another leisure battery. What is the connection I need to connect the 2 batteries
    Shirl
  2. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
    :BigGrin:In its simplest form, all you need to do is join the two batteries with a length of red cable and a length of black cable (live and earth). Battery connectors (live and earth) are purchased from any car spares shop and cost about a quid each. You just connect live to live and negative to negative, both batteries will then be charged and avai;lable for use.
    There are loads of more complicated and expensive ways of doing it, with a miriad of gadgets to fit .........if you want to.:BigGrin:
    • Like Like x 2
  3. hilldweller
    Dec 5, 2008
    26,871
    25,734
    Macclesfield
    +FUSE to FUSE+
    - to -
    That's the easy bit, but how far away will the new battery be ?
    If they are very close the fuses might not be needed.
  4. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    they will be more or less next to eachother....Does it matter that the batteries are not the same power...125amp and a 85 amp? I dont think there is enough room to add a bigger battery
    Shirl
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Hi Shirl, no it does not matter but make sure to get a test on the old battery to make sure it is good :thumb:
    terry
  6. hilldweller
    Dec 5, 2008
    26,871
    25,734
    Macclesfield
    No problem. Since there is little chance of the + cable shorting to ground ( you route it well ) then a single fuse, 50A should do just in case one battery fails dramatically. Halfords will sell you fuse, cable and connectors. They do some small reels of pretty thick loudspeaker cable. Colour does not matter of course.
  7. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    Where do I site the fuse? I have bought a positive and negative cable which has round connectors on and a set of 2 battery terminal adapters from Halfords.
    Shirl
  8. hilldweller
    Dec 5, 2008
    26,871
    25,734
    Macclesfield
    In the positive link, you'll have to break the wire and graft in the fuse, then if either batter suddenly shorted out ( very unlikely ) instead of the cable setting on fire the fuse pops.
    If the positive cable was long or at risk of shorting to chassis ( the battery negative ) you'd put a fuse close to each battery + to protect both of them.
