Leisure Battery Charging (1 Viewer)
I am thinking of this on a self build. Will the van's alternator cope with a manual switch charging system? I was keeping things simple and this looks simple enough for me
Broken Link Removed
When the switch is on to charge the leisure then the alternator is charging two. I was thinking this may be a strain on the alternator output.
Cheers for that. Just pulled the picture from Google pictures so never seen the site. This is just a budget van so looking to spend little as possible getting it up and running. The next van will be done with a relay. I will only have a couple of LED lights and a radio on in the evening so a small battery should do.
43,315
49,369
Yes, it will work just fine when the emgine is running but as Jim said.....once the engine is off it will discharge the engine battery if you forget to turn it off.
Thats bad enough but if its left on and you start the engine it will blow the fuse, you wont realise this of course....until you find the hab battery is flat, even though you just drove for hundreds of miles
Thats the reason for using an automatic split charge relay.
Reactions: DBK
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
A relay pulled from a scrap car & one extra (thin) wire to the alternator & you have split charge. Shouldn't cost more than £5 if you buy the relay new.
Oct 1, 2013
7,510
19,933
Lanzarote
Nil by mouth
Lots
Yo. I managed to fit a split charge relay to the LMH mesen :)
The kit was about £50 from Ebay.
If you ask nicely I'll send you the linky :)
the relay will not cost much more than the switch
Six quid for a switch. I would not know where to start with a relay pulled from a car and this wire that @tonyidle is talking about. Where on the alternator would this go?
