Leisure Battery Charging (1 Viewer)
Patcherelli
56
25
Bedfordshire
Coach
Swift Sundance 630G
When at home I plug the van in and run a digital inteligent charger which is designed to be left on to the cab battery. I also currently have an oil filled rad in there.
Should i leave the charger switched on to the leisure battery?
Only just realised i can switch it off and still power the sockets.
I've heard it's best to leave it off and just put it on for a couple of days a week.
Also heard its ok to just leave it on.
What's the thinking?
thanks
MikeD
3,936
3,697
London
IH PVC
Since 2012
I leave mine charging on 24/7 since we bought the motorhome.
No problems so far (y)
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
If the output voltage is suitable for float charging your battery, it can be left on all of the time.
What you have to be careful of is those multi-stage chargers that go through a full cycle if the mains supply is interrupted and then restored.
We use a single-rate charger for floating our batteries in the trailer and the Mercedes.
The solar panel controllers are multi-stage.
Peter
