Leisure Battery Alarm
Discussion in 'Tech/Mech General' started by Linda and Steph, Dec 31, 2008.
  1. Linda and Steph
    Linda and Steph Funster
    Jun 18, 2008
    1,375
    1,448
    Lancaster
    My leisure battery charger unit has suddenly started sounding a high-pitched alarm:Eeek: whenever I turn on the ignition (and it continues with the engine running)
    I've tried switching all 12 volt systems off but it just won't stop, any ideas?:Sad:
  2. Phil
    Phil Read Only Funster
    Oct 21, 2007
    226
    Herts
    The battery charger should not switch on unless you are connected to mains electricity.
    if you have an inverter running off the battery then that sounds am alarm if the battery is too low to run the inverter.
    Phil.
  3. ginge61
    ginge61 Read Only Funster
    Oct 29, 2007
    431
    n/wales
    or you need a new battery poss not holing charge the winter shows up probs like this
  4. Linda and Steph
    Jun 18, 2008
    1,375
    1,448
    Lancaster
    Nope, nothing connected :cry:
  5. Linda and Steph
    Jun 18, 2008
    1,375
    1,448
    Lancaster
    I hope not :Eek!::cry: but I'll check it out.
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,125
    3,541
    Eastbourne East Sussex
    Wonder if yours is a Rapido. The control panel over the door produces a high pitched beep on turning on the ignition which stops after a few seconds. I have no idea what it indicates but everything seems to work properly.:Cool:
  7. Linda and Steph
    Jun 18, 2008
    1,375
    1,448
    Lancaster
    Not a Rapido.
    The charger is a CBE A920 with some sort of automatic unit connected between the charger and the battery - CSB 40-B. I think the sound is coming from this unit rather than the charger itself, also, if I move any of the wiring slightly the pitch and volume change.
    I have instructions in several languages but, unfortunately, not English.
  8. hilldweller
    Dec 5, 2008
    27,885
    26,961
    Macclesfield
    Here is some English.....
    CBE srl - A920
    You might find more clues on that site.
    Brian.
