Leisure battery advice
Discussion in 'Motorhome Chat' started by Pikeman, Jul 31, 2012.
  1. Pikeman
    Pikeman Funster
    Nov 6, 2011
    292
    323
    Worthing
    Hi Folks,
    My van is secondhand and I think the leisure batterie's (have a pair), are the originals, therefore 10 years old. Still functional, but not as good as I think they should be. My question is how do I test them to determine if I should replace? :Cool:
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    you could take them to a garage and have them tested with a discharge tester.
    You could make sure they are full charged then disconnect them from the van and each other and check the voltages after 1 hour, 24hrs and one week. make a note of the readings and see what you get.
    Youu could also check the specific gravity of each cell if you have the appropriate tool to check for differances (lead/Acid only).
    If lead/acid make sure they were fully topped up before charging
  3. Pikeman
    Pikeman Funster
    Nov 6, 2011
    292
    323
    Worthing
    Taking to a garage at intervals sounds impractical. What is a discharge tester? Googling sugests a multimeter, but I am vague on the subject. Come on folks 42 read's and only one feedback - you can't all be watching Phelpes!!
  4. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,986
    West Norfolk
    As Wildman said, you need to fully charge the batteries, check the open circuit voltage and the specific gravity of the electrolyte.
    You should get 12.8V and an SG of approx 1.265 if the battery is healthy (at 20 degrees C)
    Remember to get rid of the 'surface voltage' on the battery by briefly putting a load on it.
    If you have sealed batteries, then a performance test by draining them at a known amperage over 20 hours is the only way to ascertain if they match the original performance.
    Most batteries are rated at a 20 hr rating.
    Ie a 100Ah battery will give 5amps for 20 hrs for a 100 % diacharge.
    Discharging to this level is not recommended, however because going beyond this will damage the cells. As a rule. discharge leisure batteries to 50% max (open circuit voltage 12V).
    Therefore, for testing, discharge the said battery at 5 amps for 10hrs and then measure the open circuit voltage. This should now be 12V if the battery is healthy.
    Using the power formula, to get a discharge of 5 amps from a 12V battery, you need a 60W load. A 50W bulb is close enough for this and makes a readily available test apparatus!:thumb:
    If you have traction batteries, 11.6V (80% discharge) is fine.:Smile:
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    the old fashioned, and best, version. HERE
    the new digital version....crap in my opinion. HERE
    you dont need to take to a garage at regular intervals.....just check the voltage after 24hrs, one day and one week with a cheap multimeter.
    12.7v and above after one hour off charge = 100% charge
  6. Gooney
    Gooney Funster
    Jun 2, 2010
    4,772
    7,864
    Flintshire
    Your right Paps, the drop tester is best, it induces a load situation on the battery but at £100 plus not the bit of kit Joe average carries, if you take your batteries to a local tyre battery dealer they will test using a drop tester for you for free!!
  7. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,942
    3,401
    Eastbourne East Sussex
    All very complicated. I don't think you'd want to spend £100 on a discharge tester. Suggest you could connect the fully charged battery to a car headlight bulb (55w) which you can get for under £2 which will draw around 5 amps. If its still bright after 10 hours (110Ah battery, 8hrs 85Ah battery) then your batteries are fine, if it dims after a few hours then they need replacing. Don't run it for longer than this though or they will need replacing anyway through over discharging. Take care the bulb will get very hot.
    Alternatively if you're sure they are 10 years old they will almost certainly need replacing anyway. If still readable there should be a date on the batteries.
  8. pappajohn
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    I wasnt suggesting the op went and bought a £100 drop tester....simply answering his question "what is a discharge tester" :thumb:
  9. Pikeman
    Pikeman Funster
    Nov 6, 2011
    292
    323
    Worthing
    :thumb: Thanks everyone, Ive learnt stuff tonight! Will act on your advice.
    This is why I joined this community!
  10. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,289
    16,961
    Liverpool.
    Machine Mart do a good drop tester for around £30 if I remember right. Its some time since I bought mine and its well tried and tested. Not digital, it has a meter on the front and 2 crocodile clamps that attach to the battery with a heating element inside. Good piece of kit and will pay for itself over time.
    Good news, have just checked and its £23.98 and its the CVT1 model you want.
    • Like it Like it x 1
