Leisure Batteries ?
Discussion in 'Tech/Mech General' started by jezport, Oct 17, 2010.
  1. jezport
    jezport Funster
    Oct 29, 2008
    1,821
    1,227
    West Yorkshire
    I need to replace the 230ah battery that the last owner of my van fitted about 18months ago. It will only run my 15" LCD for less than 3 hours. It gradually drops to 12.3v over 3 hours then plummets to 10.5v. As the TV only uses about 4Amps and I know that the charging is working + I have 2 large solar panels with a volt meter.
    What size battery do I really need?
    We use the van all year so the 220W solar panels keep us going most the year, and we have a small genny for emergencies. We have all LED lights TV uses 4Amps + we use the blown air heating.
    Would a 110Ah battery be good enough to get us through a night of the kids watching TV and the Truma heating on for a bit? Or should I go for something between 180 and 220AH or 2 x 75Ah batteries.
    I am a costco member and have been told that they sell Bosch 110Ah batteries, so I could always get one and see how I go because they will take it back if I am not happy.
    Any advice would be appreciated
  2. hilldweller
    Dec 5, 2008
    27,217
    26,206
    Macclesfield
    We manage at least 3 days of TV and heat out of 85Ah. Small TV.
    Your TV 4A so 20Ah for an evening, or are your kids completely square eyes like a lot ( inc my grandchildren ) these days.
    So either batter has had it or charging system isn't working or both.
    Go get your 110Ah, make sure it charges to over 13V maybe as high as 14.5V then see how you get on.
    If you haven't got a simple voltmeter invest in one for under a tenner and this will make sure you are reading the right voltage.
  3. jezport
    jezport Funster
    Oct 29, 2008
    1,821
    1,227
    West Yorkshire
    My electroblock charger was recently changed and when connected to a semi discharged battery charges to over 14volts, same on alternator and same via solar panels. If the battery is only slightly discharged it charges it upto about 13.9v and then floats at 13.6 to 13.8v on either solar or charger. I can also see the current from the solar panels as well as the voltage and know that once the battery is fully charged the solar regulator is cutting the charge, so it is not over charging the battery.
    To me this sounds OK. Am I correct?
  4. hilldweller
    Dec 5, 2008
    27,217
    26,206
    Macclesfield
    Sounds good to me, so I/we wonder what killed your battery. If the electroblock was changed maybe the old one let it go into deep discharge.
  5. jezport
    jezport Funster
    Oct 29, 2008
    1,821
    1,227
    West Yorkshire
    It failed in the summer so my solar panels kept it charged, and it never got below 11.9v when used, so it beats me. The battery has a green health indicator and it is still showing green.
  6. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Sounds like it has a duff cell..
    My own take on battery size is to fit as much capacity as you have physical space for ..
    Truma fans use 0.2-5.6 A depending on speed .. so with TV + Truma = almost 10ah
    A 110 ah battery has a useful capacity of 50 ah .. give or take, so about 5 hours will see it effectively flat ..
  7. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Spooky:Eeek:
    This is exactly the same as our pair of 120ah batteries due to be collected today for test and replacement (yes I'm about to see if the warrenty is any good:Doh:), right down to figures and timing, like I said spooky......:Eeek:
