Leisure batteries
Discussion in 'Motorhome Chat' started by Ains-campers, Feb 18, 2016.
  1. Ains-campers
    Ains-campers Funster
    Nov 2, 2015
    10
    10
    Lancaster UK
    Hi guys, it seems we need a new leisure battery in prep for the Peterbourgh show. I've looked on here and read about batteries etc but it's still well over my head and I haven't got a clue! I've seen some on Amazon one stands out due to its reviews Numax leisure battery 12v, 100ah, 1000CCA, it's advertised at £70. Is this a good price or make? Should I stay away from Amazon and buy from a specific retailer and it still confused what this 100ah/ numbers code thing means. Any advice welcome
  2. seanoo
    seanoo Funster
    Nov 14, 2009
    368
    224
    normandy
    Battery megastore uk , Hankook DC31 , excellent leisure batteries and great price
    • Like it Like it x 3
  3. Spanner
    Spanner Funster
    Nov 7, 2015
    96
    44
    Shropshire
    Tayna batteries, online all the makes, Very professional and extremely competetive
    • Like it Like it x 1
  4. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,587
    2,574
    Cornwall
  5. Ains-campers
    Nov 2, 2015
    10
    10
    Lancaster UK
    Thanks for the link it seems like 'banner' is a popular brand and the bigger 'ah' is better and the link certainly helped cheers
  6. Ains-campers
    Nov 2, 2015
    10
    10
    Lancaster UK
    Just had a look on the megastore thanks for the recommendation, great choices and prices
  7. Tincataylor
    Tincataylor Funster
    Jul 9, 2012
    414
    745
    Devon
    I was told by someone who is supposed to know about these things that the construction of the battery, irrespective of the manufacturer, should be compatible with the type of on board charger you have fitted to your van.
    The Tincas
  8. Ains-campers
    Nov 2, 2015
    10
    10
    Lancaster UK
    I see that would make sense. This is well over my head, more research it is and more checks to our van.
  9. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,376
    5,633
    Guisborough
    Hi Ains-camper
    The 100ah is the capacity of the battery, so it should give you 100 amps for one hour or 1 amp for 100 hours, I say should as for a start you should not discharge lower than 50% which would be about 12.2 volts with no load on the battery, so straight away your 100ah battery is only really 50ah useable.
    The other figure of 1000cca is saying it will give 1000 amps for a very short burst to start an engine, engine batteries tend to have lots of thinner plates to give this burst of power where what we want is less but thicker and heavier plates to give a reliable steady drain of power.
    For a starting point I would look for the heaviest battery at a given capacity as this is a pretty good indication of its quality. As The Tincas says you need to make sure that your new battery and your charging system are compatible so if you are looking at a battery that says its Gel or AGM or flooded lead acid, make sure that your chargers both mains and solar have a setting for the battery type of favour.
    Then comes price I am sure you can get a 100ah battery for £70 or you could pay closer to £200 so you have to make your own decision as to whether the more expensive batteries are a benefit to you.
    Of course the most important thing is make sure that whatever battery you buy it will fit in the available space in your van.
    Martin
    • Informative Informative x 1
  10. kaasbroodje
    kaasbroodje Funster
    Sep 14, 2013
    794
    894
    Bristol
    Do a search for 'Banner batteries' they are popular but opinion is divided as to whether they're good...
    My preference is Varta, have previously bought from Tanya and Battery megastore, both being good to deal with.
    On the high street, gooutdoors are usually competitive on standard leisure batteries (y)
  11. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    Whatever you decide, before you buy check the dimensions of the battery against the maximum size you can fit into its location. You don't want to buy a battery and then find it's too big :)
    • Like it Like it x 2
  12. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,216
    3,630
    walthamstow east london
    my vote would be for trojans but do check the dimensions as they are not standard sizes and they weigh a lot
  13. Ains-campers
    Nov 2, 2015
    10
    10
    Lancaster UK
    Wow thanks guys a massive help. I didn't even know about of think about how it's charged. We've only had the van a month so it's all completely new and a mine field. Our current battery only lasts around 15mins and it had been charged via mains whilst parked up on site and I assume driving also charges it?? hence why I'm thinking its pooped and we need a new one. Next on the agenda is to find where it is, size it and find out which charging system is used. A real big help thank you!
  14. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,980
    1,729
    Bungay Suffolk
    Check the fluid levels in each cell and if necessary top up with distilled water. Then try battery again before you splash out.
  15. harblights
    harblights Funster
    Mar 5, 2016
    21
    20
    Trefin/Porthgain
    Having read all this I am going back to photonic universe for two of their gel batteries as my batteries are beneath the drivers seat. Had originally gone for two 90 amp gel batteries with Dethleffs but they fitted AGM batteries which died within weeks although we did not realise as at the time we where mainly on hook up. It transpires that the Shaudt EBL101 that is under the passenger seat does not support AGM batteries only Gel or Acid. Very disappointed with Dethleffs for this schoolboy error Orr skimping on battery cost!
  16. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,492
    6,481
    West Sussex
    Most of the Hymer group have been fitting AGM's for a few years and only been fitting a suitable charger for a few months. Just replaced my AGM's with Gel's.
    • Thanks Thanks x 1
    • Useful Useful x 1
  17. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,940
    3,400
    Eastbourne East Sussex
    If youre buying a different battery check the size first so it will fit in the space available. Tayna shows dimensions on their site.
    • Thanks Thanks x 1
  18. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,246
    3,490
    Rural South West Wales.
    Be aware that not all MH's alternators charge the leisure battery whilst driving - our 2010 Autoquest 145's doesn't - soon to be rectified :)
    • Thanks Thanks x 1
