Leisure Batteries (1 Viewer)
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
I know from the information I've gleaned on here that my two leisure batteries are best matched.
In our "new to us" MH which we collect on the 1st June there is an 85 amp/h battery under the driver seat fully filling the available space and I have a similar but not identical 95 amp/h 1 year old battery, which I plan in the short term,to add to it.
Can I ask what damage I'll do to the mis- matched batteries or to anything else?
Thank you again
Ian
funflair
19,331
30,171
Guisborough
MORELO palace
since 2012
I will go with Brian on t his one, as long as they are both flooded lead or whatever it should be OK.
IanF
May 7, 2013
845
1,353
RUK
Thank you guys
3,869
5,262
The City of Henlow
Adria Supreme
Since 1980
The leisure battery in my Fiat goes under the passenger seat at the front but there is room for two batteries; just.
You should not mix leisure batteries with Starter Batteries, they have different properties and I understand that if you fit an 85 ah and a 95 ah battery in parallel, the effect will be to have only the benefit of the lowest powered battery x 2
IanF
May 7, 2013
845
1,353
RUK
Hi -Unlike your arrangement the battery under the drivers seat is the Leisure battery. The starter battery is in the engine compartment.Thanks for your response.
Ian
Lenny HB
53,404
149,851
On the coast in West Sussex
Hymer B678 DL
Need to know how old the battery in the M/H is ideally both batteries age should be less than one year different in age.
If fitting under the seats I personally would only fit a fully sealed battery either a Gel or AGM.
43,319
49,388
A 20ah battery joined to a 5000ah battery will give you a total capacity of 5020ah
Your charger can only see one large battery, it cannot differentiate between batteries of different ah rates.
Same applies to discharging the batteries....power is drawn from the total capacity of both batteries, not one battery before the other.
Absolutely no problem mixing different ah ratings...age and condition on the other hand, can be battery killers.
an old battery wont be as efficient as a new battery and will pull the new one down to the same efficiency as the old, worn out one
IanF
May 7, 2013
845
1,353
RUK
Thank you for that clear explanation pappajohn.
Ian
3,869
5,262
The City of Henlow
Adria Supreme
Since 1980
Ian
It is a leisure battery under my passenger seat and there is (just) room for two batteries there. Sorry if I explained myself badly.
IanF
May 7, 2013
845
1,353
RUK
No please don't apologise you have just made me aware that there might be either a battery under the"captains" passenger seat that I am presently not aware of ,or if there isn't, a real possibility of fitting one in there.
I don't get the MH handed over until the 1st June and can't wait for that day. I'll certainly check this idea well out
Thanks again
Ian
