Leisure Batteries - Tell Me Why This Isn't Sensible
Discussion in 'Motorhome Chat' started by Sidney, Oct 12, 2016.
  1. Sidney
    Sidney Funster
    Jan 27, 2013
    1,219
    797
    Stamford
    [​IMG]
    Why should I not install "Absolutely Maintenance Free" leisure batteries to the chassis?
    Advantages:
    No vent/gassing, no maintenance
    Can be located in a perfect position for weight distribution left/right front/back
    Lots of extra storage in habitation & garage
    Disadvantages:
    Road muck & grime
    Cannot be inspected easily
    Need the wisdom of some Funsters to help me make up my mind
  2. Teuchter
    Teuchter Funster
    Nov 4, 2014
    505
    1,669
    Lee on the Solent
    Road muck & grime will not harm the battery but might eventually cause some crud around the terminals, it is also possible that stones from the wheels could damage the battery casing.
    The main problem in my view is the cable entry from the battery to the habitation area
    • Useful Useful x 1
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    No reason why not.
    Bit of brake grease around the terminals twice a year to keep them clean.
    All four of mine were open to the elements.
    Many commercial trucks have the batteries chassis rail mounted.
    Unless the carrier is galvanised it will need some maintenance to keep rust at bay.
    As its attached to the chassis it MAY come under MOT rules regarding fixing security etc.
    • Useful Useful x 1
  4. PhilG
    PhilG Funster
    Mar 8, 2016
    492
    665
    leicester
    I had underfloor batteries on my 7.5 tonner, was a pain in the arse , got covered in crap, terminals corroded and it was a mare to swap them out , not something I would want to deal with again.
    • Thanks Thanks x 1
  5. aldhp21
    aldhp21 Funster
    Feb 17, 2009
    239
    1,002
    Cheltenham
    We had a CI 706 until about 4 years ago. That had a leisure battery underneath the vehicle in a cradle. I moved it to under the lounge seats when I added a second battery.
    • Informative Informative x 1
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,940
    West Norfolk
    Cold.
    Cold batteries will loose a fair bit of their capacity due to cold, just when you need the most from them.
    • Like Like x 3
    • Useful Useful x 1
  7. pappajohn
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    Easy solution.....
    120ah instead of 110ah....almost 10% more capacity
    • Like Like x 1
  8. Sidney
    Sidney Funster
    Jan 27, 2013
    1,219
    797
    Stamford
    Interesting that some manufacturers use them. I didn't know that.
  9. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,893
    somewhere
    If you intend to be off grid not a good idea you will get better life if you treet them right
    Thar like women be bad to them and come bed time thay will level you in the dark with no pleasure cold battery's are like cold women thale drane you to the max
    Bill
    • Funny Funny x 7
    • Like Like x 1
  10. EssexBoy
    EssexBoy Funster
    Feb 5, 2009
    330
    230
    South Essex
    My 2008 CI Carioca had its batteries in an outside wind-down purpose-made cradle...
    Admittedly it got covered in crud, but worked fine otherwise...
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,086
    2,927
    Kendal, Cumbria
    A "Beeny Box" type of battery container would overcome most of the problems mentioned. Or fit a LPG tank & free the gas locker.
  12. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,171
    1,937
    Cannock Staffordshire
    Personally i think its a damn good idea, if being worried about open to the elements of crud you could always make some sort of deflector or cover to keep the crap off them.
  13. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,107
    9,744
    Lorca,Murcia,Spain
    both mine are outside in a solid cradle. don't really get any muck on them ,even when in the UK.
