leisure batteries on permanent charge
Discussion in 'Motorhome Chat' started by lebesset, Apr 30, 2010.
  1. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    haven't used the motorhome for a few weeks now , and it suddenly occurred to me that the batteries are being constantly charged by the array of solar panels
    so I put the meter on the 12v output to see what voltage they were actually showing ...answer ...13.9 volts
    question is , is it ok to constantly keep the batteries at this voltage[ well , not overnight I presume ], I am aware that the amperage isn't that great , but don't really know if the batteries being kept under charge will suffer any damage at this level
    any info on this ?
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    unless your solar charge regulator is faulty the charge rate will have reduced to a milliamp float charge and is quite normal. the charge rate will rise as you put a load on it.
  3. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    There are some cheap (14 euros) non smart chargers about that use a simple relay to turn the charge on and off. They take the charge voltage up to 14.2v then turn the charge of until the voltage comes down to 12.6v.
    I have had one for about 4 years and it works great, when the MH is not in use the battery's take over a week until the voltage has dropped low enough to start the charging again.
    Doug...
  4. atakd
    atakd Read Only Funster
    Nov 15, 2009
    106
    Wirral
    Some info below I got when posting on solar charging on a sailing forum. I decided to stay with my basic regulator but if it fails I will probably upgrade to a PWM.
    I have a 40W panel and one of these
    http://cgi.ebay.co.uk/New-100w-12v-7...item2c529960ff
    regulators. When the panel charges the battery in bright sunlight the voltage rises rapidly then charging ceases for a while, then resumes.
    My question is, do all regulators deliver pulsed charging, meaning precious periods of sunlight go unused, or is a regulator available which limits charging current whilst delivering a safe, continuous charge? Or does it make no difference?
    TIA
    Andy
    [​IMG]
    I recently went thru this for a 30W panel. Basic advice on here was to get a PWM (pulse width modulation) regulator- much more efficient than standard regulator and not much more money- cost about £15-£20 and I paid £28.99 for a 2 battery unit.
    Better still is evidently a MPPT regulator (multi-point tracking- about 30% more efficient than PWM) but these are still pretty costly- cheapest about £50-£75 for a single battery unit on Ebay.
    If you want an LCD readout for charging rate, battery state and charge etc, then these units are normaly £100+, tho I did get an add on meter for mine for £36, which was pretty good value I feel.
    HTH ​
