Leisure batteries issue
Discussion in 'Motorhome Chat' started by Douglas1, Oct 10, 2016.
  1. Douglas1
    Douglas1 Funster
    Oct 4, 2016
    19
    6
    Cheshire
    Can anyone help on this.I have a Hobby Toskana 750,I use the inverter now and then,I'm aways cautious of draining my 2 leisure batteries, so just limited use now and then.I do have 120w solar panel as well which keeps them topped up.
    Today I used a 900w hairdryer,I switched the 2k inverter on and I also switched the engine on,everything was fine until i switched to full power on the hairdryer,the volt reading went from 12.7 down to 0.1 and it cut off.
    A volt meter shows both engine and alternator are charging and working fine and give a reading of 13.5.But the engine battery has stopped charging the leisure batteries, I've checked the fuses under the drivers seat,all are ok. There seems to be no power at all to the leisure batteries from the alternator on engine startup.
    I've hooked up to mains and all batteries charge with symbol on panel showing this.We do a lot of wild camping so if anyone has any thoughts on this,I'd appreciate it.
    Both leisure batteries and engine battery are fairly new and do hold their charge.Is there a fuse or something stopping the engine battery charging the leisure batteries?
  2. Vanman
    Vanman Funster
    Aug 12, 2016
    683
    386
    Runcorn
    Only a guess, but does the controller favour the cab battery until it's recovered before it will use the excess to feed the others?
  3. Douglas1
    Douglas1 Funster
    Oct 4, 2016
    19
    6
    Cheshire
    Good possibility, but i put a volt meter on the cab battery and it reads 13.7 volts, it's only the instrument panel in the motorhome that displays 0.1 volts.
  4. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,665
    7,391
    Plymouth
    :)chuck the hair dryer in the
    e bin and buy a brush ....sorted :)
    • Like it Like it x 1
  5. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    Repeat post?
