Leisure batteries discharging too quickly! (1 Viewer)
makems
3,439
27,697
Ingleby Barwick,,Teesside
Sadly had to give up
Bear with me....
We havea Rapido 983M currently with two 85Ah batteries (new within the last 6 months) plus two 80w solar panels. Currently in Portugal and having electrical problems.
Once the batteries are fully charged, we only get about one hour ov TV and a couple of hours of having a couple of lights on before the panel shows the batteries at less than 12V and the alarm goes off.
Two nights ago we went out and didn't use the TV or lights at all (candles only when we got back in). Next day solar panels had the batteries back to 12.2V (as shown) so we used candles again and didn't use anything electrical except water pump. At 5:00am the panel alarm went off showing batteries fully discharged at 11.0V !
Last night I carried out an experiment - solar panels had the batteries back up to 12.2V again and after another evening by candlelight I turned the panel off completely using the main switch - in the morning the panel showed the batteries still at 12.2V.
Interesting - but what the hell can be draining the juice?
Anybody got any ideas?
I might not be able to respond very quickly to questions or comments as I'm having to walk into town to find a cafe with wifi.
All advice gratefully received.
Mike
Dec 6, 2011
11,580
25,399
South Wales
Coach built Adria
i'm no electrician...:Blush:. but i would expect a battery to better 12.2v when fully charged; i think:Eeek:. also if its disharging when the panel is still connected do you have a drain back through the solar panel?:whatthe: may be a diode fault? :Angry:
but i am sure someone else will have more specific help.:thumb:
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Bear with me....
Mike
Hi Mike, I am in the UK at the moment but I will be in my MH at Olhao this Monday night, if I can be of help get back to me and I'll see what I can do.
Doug...
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
At 12.2V the batteries are virtually discharged a fully charged battery is around 13.8V. In the winter the sun is too low in the sky for solar to produce much more than milliamps in the UK, no idea about Portugal, JJ is the man for those answers as he lives there. You need a generator or mains hookup to charge the batteries properly. If you are wilding and parked up for long periods then maybe a wind generator would help. Otherwise driving every day will be needed. A number of things may be draining the power, a leaking tap, radio, alarm, outside light, fridge, inverter, etc. with 2 85amp/hr batteries you should have 85amp/hrs of useable power, assuming the batteries start off fully charges then something is using a lot of power. If you have and know how to use an ammeter then switch everything off one at a time and write down the current drawn Does the engine battery hold a charge ok
are the sealed or lead acid batteries, if lead acid do any of the cells need topping up,
check charge of each cell with a hydrometer.
Check battery connections are clean and smear with vasaline.
check inline fuses between the two batteries
check to see if voltage rises when the engine is running
When in full sun voltage should show at least 13V and more if not then it is insufficient to charge. The solar panel may be faulty what output is there from it, how many amps or milliamps is it charging.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
12.2 V is flat.
Fully charged you want to see 13.6 - 14.5V.
Try and get on hook-up before you destroy your batteries.
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
Try running your engine for a couple of hours, to put some charge in your batteries
if you are stationary. If this improves their conditions(level of charge), that will point to
your solar not doing what its meant to do. You can then investigate that, but try to maintain batteries even if it means running engine or you may damage them beyond recovery.
Candles bad idea in motorhome!!!! Go buy a torch..
Regards
Steve
43,319
49,404
no wonder you only get a short time from your battery....12.2v is only 50% charged and is classed as flat.
voltage should be checked an hour or so after charge and before any power is used but fully charged should show around 13.6v immediately after charging.
check out the chart below..
makems
makems
3,439
27,697
Thanks for all the replies guys.
I know that 12.2V is nowhere near fully charged, but the batteries were fully charged before that.
We're on a hook up today so will get a full charge and then we can see where we get to.
Now for some specific answers:
Phill D - if its disharging when the panel is still connected do you have a drain back through the solar panel?:whatthe: may be a diode fault?
I did wonder about whether there could be a drain back through the solar panels. Would that drain be affected by switching everything off at the panel? I would have thought that the panels would be connected directly to the batteries via the solar controller rather than via the panel (but I'm no expert).
Wildman - If you have and know how to use an ammeter then switch everything off one at a time and write down the current drawn
I have a multitester but I can't say I'm familiar with using it as an ammeterDoes the engine battery hold a charge ok
Yes are the sealed or lead acid batteries, if lead acid do any of the cells need topping up,
SEaled
Connections are clean-the batteries wereonly installed in October
I will check this-do you mean that if the fuse is blown in effect I've only one battery?
Will check all this.Battery going on laptop - sh*t!
Dec 6, 2011
11,580
25,399
South Wales
Coach built Adria
On the drain back through the solar panel... diodes are in place to prevent this from happening however, they can fail and this will allow drain back and a level of discharge.
from all the information you have now supplied it seems to me that your batteries were drained to the point where the poor solar panel was incapable of keeping up with the required charge in the "short sunlight" days we are having this time of year.
also, as a thought the hook up should sort you out to a base level to establish some real facts from. however, i am not convinced a standard motorhome charging system is fully capable of replenishing batteries to an absolute full state of charge, they may need to be placed on a proper bench charger to do this. But! i could be wrong here.
good luck with getting this sorted. will be interested to know the outcome.:Eeek:
makems
makems
3,439
27,697
WE got a full day on hook up yesterday after which the batteries were showing 12.7V.
We decided to be a bit daring and use one of the lights! Just one mind! It is a 10w halogen and after about four hours use the panel was showing 12.6V. Not sure if should be worried about a drop of 0.1V after consuming only about 4Ah of capacity. I turned the panel off completely overnoght and the panel still read 12.6V this morning just before full light (a full bladder got me out of bed, not the compulsive need to check the panel).
Today I opened up the battery compartment and discovered that I had 2x75Ah batteries and not 2x85Ah as told by the supplier. I'll have words with the robbing b*stards when I get home! :Angry:
I checked and there is no in line fuse between the batteries - should there be?
Also they needed a bit of topping up - in fact between them they took about 750ml of distilled water.
Today has been a bit of a scorcher and during the early afternoon the panel was showing bwtween 13.0 and 13.2V-presumably this means the solar panels are now doing their job?
Tonight we might get a bit bolder and try to watch a DVD for an hour.:RollEyes:
I don't know if this saga is of any interest to anybody but I'll keep updating it just in case.
Mike
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
Obviously not good on the batteries being of a lower capacity than you were given, but they should still work.
A fuse should always be fitted between two batteries.
The low water level would not have helped with the capacity and may have caused some damage to the batteries.
As you say at least it sounds as if your solar panel is working
OK.
Mike
ciderman
380
416
derbyshire
Hymer 754
4 years old
the other thing you could do is check the voltage at the batteries to see if they are equal charge if not one could pull the other down
kelpbeds
100
12
shrewsbury
c class
since 2006
I've had some interesting battery problems recently. Check for posts under my name.
You could change to traction batteries, which go for a lot longer than leisure batteries, but more expensive and give off hydrogen and need to be vented.
You could go for a battery to battery charger, which ups the ampage from the alternator to charge your batteries around 5 times faster (but no good if your batteries are already rubbish)
Might be an idea to uprate the earth from the leisure batteries, certainly won't hurt.
And, yes batteries should show around 13.6v when fully charged but this isn't a true reading of their real charge and this figure will soon drop to the real level which should be around 12.8v at full charge.
Good luck!
43,319
49,404
OK.
Mike
in addition to this excellent advise......you should fit a fuse at BOTH ends of the connecting wire.
reason being, if the link wire should short to earth, more probable if the batteries are spaced a bit apart (one under passenger seat, one under dinette seat), then the single fuse would blow isolating the battery with the fuse between it and the earth fault...but the unprotected second battery would still be shorted to earth.
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Mike
Of course it is, keep going mate:thumb:
motorhomer
680
418
South Shropshire
Van Conversion
since 2005 (but 30 years caravanning)
Just another thought.
I also have a rapido, on mine the volmeter on the panel can be adjusted, and could be reading wrongly. I looked into mine because I thought it seemed low althought in other respects it worked OK.
Have you tried measuring the voltage across the batteries themselves, not through the panel?
I did this on mine, and discovered that there was a large discrepancy on the leisure battery, (although not on the vehicle battery) - be careful though as you might expect a little voltage drop.
I adjusted the panel setting for the leisure battery, and all is now well and the panel reads as it should, and the battery (only one) lasts several days including lights and occasional TV when wildcamping.
chatter
3,689
937
cheshire
5th wheel
once you have sorted your batteries out, you also should look into changing your lights to leds, just as bright and use a fraction of the power halagen ones need
makems
makems
3,439
27,697
Th\nks for allthe continuing replies- most helpful and encouraging.
We watched an hour of a DVD last night (load of sh*te about a Prime Minister having to sh*g a pig that I recorded from TV in December) and also had the lights on fr about 3 hours. Battery showed 12.5 volts at bedtime.
Today has been bright but cloudy most of the day (windy and chilly too!) but the panel was reading between 12.9 and 13.0V most of the time soI think the panels are definitely working.
The batteries also seem to be holding their charge although admittedly under a pretty light load.
The next test is to leave the panel on overnight to see if I can replicate the issue of the batteries draining overnight - just in case there is a problem with the solar controller allowing the current to drain back from the batteries.
I'll get the lying supplier to rectify the missing fuse between the batteries (I presume this is best practice and they should have followed it?)
I'll also dig the multitester out of the tool locker and see if I can work out how to test the voltage of the two batteries. I presume it's one probe on the +ve terminal and one on the -ve?
Must get back to van now-it's my turn to cook and SWMBO will not be pleased if her dinner's not on the table at the allotted time. (I don't want to spoil the romantic atmosphere that has been generated by those candle-lit evenings):winky:
Mike
motorhomer
680
418
South Shropshire
Van Conversion
In reply to newly retired (sorry for the delay):
on my van you press and hold the menu button on the control panel. A menu comes onto the screen. You then press the arrow button to change from the clock setting menu to the full menu. You can then page through the various items until you get to the leisure battery voltage, which you can then adjust.
Can't be sure yours is the same, its a different model rapido.
JeffO
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
put tester on dc volts setting over 12v usually 20v or 200v.
red probe to +positive black to -negative,however to check voltage of each battery seperately
you will need to disconnect one of the terminals on one battery or else you will get an average reading over the two.
Regards
steve:thumb:
makems
makems
3,439
27,697
To Broken Link Removed
Thanks for info on calibrating panel.
What panel do you have? Isita Scheiber?
Mike
makems
makems
3,439
27,697
Been out and about for a couple of days but here is the latest.....
In scouting for a new free-camping spot we came across some Brits who were exceptionally helpful when we got to discussing the ills afflicting our various vans.
One chap had a multimeter and tested the batteries. They each read 13.3V and this was in full sun (and it was quite hot I can tell you!)
So the solar panels definitely seem to be working.
He also had a look at the batteries for me (he's a full-timer and has an unbelievable solar/electrical rig). I didn't know this but the batteries apparently have a little window which should show green if they are OK and black if they aren't. One was showing green and the other appeared to be black (which was told is not good). I say "appeared" because the window was in a slightly awkward spot due to the position of the battery in the garage and had to be viewed with a mirror.
So this points perhaps to a duff battery which might make sense some of the speed with which the batteries discharge ie if I've effectively only got one battery working. :cry:
Something else this chap spotted was that one of the lights on the solar controller indicates whether the controller is charging (solid green) or whether the batteries are fully charged (flashing green).
The light was solid green bit it was a bit early in the day so it might have been that the batteries were still being charged.
However we have been on hookup for about 24 hours and the light is still solid green. I would have though it should have been flashing as the batteries MUSTbe fully charged by now.
QUESTION: If one of the batteries is duff, would the controller keep feeding it juice and the light therefore stay solid? Or is it possible the controller is b*ggered as well?
I've found a yacht chandler in Ayamonte who is selling 110Ah batteries for €107 which is pretty competitive so if I can work out if replacing the batteries is the solution I might go for this. But I don't want to blow €214 and find I haven't solved the problem!
Any help gratefully received.
Mike
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Those little windows aren't too reliable however if one is black its pretty definitely shot, the one which is green may not be good either though. If possible try disconnecting the black one, you may then find the other charges up properly if its just the other one thats bringing everything down.
Its still a good idea to replace both though as the system usually works at the level of the worst one.
makems
makems
3,439
27,697
NearlyRetired - thanks for the reply.
I've had the vanon hookup the last two nights and this afternoon when I checked the solar controller the lightI referred to in my previous post was now flashing. Indicating - according to the very brief and slightly confusing manual (poorly translated from Chinese!) - that the battery is fully charged. Hooray!
However when I checked slightly later it was solid again indicating that the battery was being charged. But nothing was switched on in between times.
I'm more convinced now that the batteries are at least part of the problem and will replace them after the weekend when we move off.
I've started a separate thread re the solar controller.
Mike
